Question about Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Picture has shifted to the left
Just recently, the picture on my tv has shifted to the left, cutting off about 1/3rd of the picture and leaving a black bar on the right side of the screen. DVD's play with no shift, this only occurs in TV mode. Even if I unplug the cable from the tv, the "snow" where the picture usually is, is shifted to the left. Does anyone know if this is a setting that has changed or is it a technical issue with the tv. With it being a 42" plasma, they want to charge $300 just to come to look at it and tell me what it could be.
  • 1 more comment
  • nader19 Sep 10, 2007
    Thanks, I actually had already found that forum after I posted this, had ordered the part, and just this past weekend, completed the instructions and it worked like a charm. What is a shame is that when I called Panasonic, they knew nothing about how to fix it and i had to figure it out myself on the internet. I have the jig which cost me $60 bucks. I'm willing to rent it out to others who need it for $10.
  • nader19 Oct 24, 2007
    you can call panasonic and they will send it to you or email me and i'll sell it to you for cheaper since I dont need it anymore
    wikiprofit@gmail.com
    also check out my website
    http://wikiprofit.googlepages.com/index....
  • jguard11-mem Apr 12, 2009
    Picture is shifted to left in when game console is plugged in.  No problems with TV picture or DVDs.
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
Posted on Sep 07, 2007
SOURCE:
Hello, I have a Toshiba 27AF45C television. The problem I am having is that the image on the screen is shifted over to the left, cutting off the picture and not giving the full view. I was just wondering...
Hello
Horizontal 'Shift' is the problem to your TV. There are so many causes to this fault. Must troubleshoot from horizontal output section to video IF section. The main board has the trouble. If you can get its mainboard as card basis at your town, it will be best to replace it as card basis.
This is the picture of the main baord.
Mar 23, 2011 | Toshiba 27AF45 27" TV
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
My sony Tv picture has shifted to the left
My tv is no picture but they have sound & power
Apr 29, 2008 | Sony KV-32FS13 TV
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
No picture but has sound
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Toshiba TV picture has shifted high
if it cannot be adjusted then there is a problem in tv. your problem is in vertical output circuit Can this be corrected easily ? yes or do I need to start looking for a new TV? I love this one and would like to keep it a while longer. not to look for new tv.you will keep it for longer that has a picture that recently shifted upward and now cuts off about 1 inch of the top of the picture. Otherwise it functions properly. your problem is in vertical output circuit please check 1loose contact in vertical output section 2 capacitor defective in v/output. it is a common problem. it is a not a major problem. if you are not tech person get it done by skilled tech. hope this will help.
Sep 30, 2007 | Toshiba 32A33 32" TV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Open Questions:
See all Panasonic TH-42PD25U/P 42 in. Plasma EDTV Questions
Panasonic TH-42PD25U/P 42 in. Plasma EDTV Logo
707 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
