Question about Fujinon Techno-Stabi Jr. (12x32) Binocular
Repair Techno-stabi binoculars 12X32
They won't power up. The battery compartment is fine. 3v is connected to the wire that disappears into the binoculars. I need to take them apart to get at the electronics. How do I do that? I have found most of the philips screws that seem to hold the case together but how do I break the seal? Do I need to undo the lens ring screws?
I have a set of Minolta pocket binoculars. One side rattles and is hard to see out. One side gets great vision. Where can I get this repaired. They are the set with the zoom.
Posted on Oct 14, 2008
SOURCE:
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
Fujinon Technostabi 14x40--battery compartment,clip that holds battery in place broke off,need new battery compartment
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
Nov 28, 2009 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Broken rubber seal on batterie cover
Goto auto shop. any name. grab a tube of permatex, blue red don't matter. this seals better then sillacone. sronger lasts longer. put a vare thin bead around the cover. NOT to much abut the same as the old seal. Now let that sit over night, be for putting it back together, or it'll be a real pain opening it back up. this will keep everything out. I've dun this more then once. good luck.
Mar 20, 2009 | Fujinon Techno-Stabi Binocular
No zoom function on a kalimar power zoom scope,
larry389's so-called solution is not a solution... just an opinion to which each individual is entitled... even when not correct! I've used a Zeika Opt. Co. Power Zoom Binocular No.25361 for over 25 years since inheriting them from my father who purchased them in early 1970. To say the least, treated carefully and with respect for the delicate instrument that they are, they've been wonderful and still work perfectly fine. Perhaps Larry's experience is based upon handling them like junk and, therefore, reaping what he has sewn.
Jan 21, 2009 | Optics
Vivitar binoculars 10-21
It is not clear what you have. If you have binoculars there is no battery. If you have a monocular night visison by Vivitar look on the side for a small round plug with a slot in it. It takes a 3v round flat battery.
Aug 20, 2007 | Vivitar PV Binocular
Fujinon Techno-Stabi Jr. (12x32) Binocular Logo
498 people viewed this question
Top Fuji Optics Experts
Marvin
Marvin
Geoff White
Geoff White
Are you a Fuji Optic Expert? Answer questions, earn points and help others
