Question about AOC LM729 17" LCD Monitor
The monitor shows the AOC splash screen then shows windows desktop, then it fades into a black screen. What is the fix for it ?
  • 9 more comments
  • Peg Chicago Jan 13, 2008
    I have the same problem and will try the steps below to fix it. Sometimes the monitor will stay on for long periods after I reset the settings in the menu. I'd rather fix it than spend money on a new monitor!
    I'll let ya know how it works out.
  • John_Castle Feb 22, 2008
    I have the same issue with my LM729 , but am not an electronics person, so I'm looking at what looks like two coils on the power supply board. They are two circular tubes with copper wrapping around them, that are laying flat on the board. Do I at this point have to turn the board around, and solder the end points better? The two places where it says D204? If someone had a picture that would be very helpful...Thanks,
  • John_Castle Aug 10, 2008
    I soldered the coils and the transformer place, and it worked for about 4 months, then it started power cycling. You will see the green light at the power button go on and off, and a brief flicker in the lower right corner of the screen. It will go on like that the whole time. Any ideas? Perhaps now the power button is sticky?
  • Anonymous Aug 12, 2008
    I have a 2 AOC LM729 that do the same thing, but i don't seem to have the same circuit board as the pictures people are showing. there are 2 points on my board that looks like they over heated the component is labeled FB901. I cant seem to find what FB stands for.
  • rodger527 Jan 04, 2009
    I have had the same problem with the LM 729 and fixed it the way you describe as below.
    The hardest thing was discovering how to remove the stand attached to back of monitor.
    1. First you have to remove the back plastic plate and four countersunk screws - this removes the monitor stand.
    2. To remove the the front silver plate, you wedge a screwdriver at the top center of the screen , and work your self downwards and outwards in both directions
    3. As described below, locate the toroid's solder joints underneath pcb board, heat the joint(s) up with a low wattage soldering iron ( Weller or anything else).
    4. A little serviceman's trick in removing solder, heat the joint up and then add solder (60/40 -7 Multicore or better) like a welding stick (plenty of resin near the affected joints), when hot then use your solder ****** (Soldapullt) or something similar) and **** off the solder (the resin does a wonderful job in the removing the solder).
    5. Check the condition of the tinning on the torrid leads, if okay then re-solder but if tarnished use a knife and clean them.
  • Anonymous Apr 22, 2009
    i have the same problem with my lcd monitor... i will try this and see if its will work on my lcd...thanks!
  • paulus649 Jul 23, 2012
    you are spot on about the chokes
  • Anonymous Mar 22, 2014
    I guess it was triggered by using windows media center to play a video,and a warning message appeared on the screen but I can no longer read it.
  • Anonymous Mar 25, 2014
    I got this error massage after i install the new aoc monitor
    Type - AOC 19" Class Slim E970Sw
    Massage -
    ----Cannot Install this Hardware.
    There was a Problem installing this hardware 1970W.
    An error occurred during the installation.
    A service installation Section in this INF is invalid -----
    What is the Problem ?
    How to fixed this problem ?
    Massage -
    Problem Solver:
  • 8 Answers
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • Flea337 Jul 26, 2008
    I just fixed mine as well (pictures attached). I resoldered both Inductance coils L201 and L202 (2 pins each), and for good measure I resoldered the L902 transformer as well (4pins).
    Dry solder joints are solders that are not making a good connection with the printed nodes on the circuit board.
    The solder joints may look good, but I would suggest taking the coils off and soldering them back on. Be sure that you do not apply too much solder, and try to heat up the board as little as possible or you may separate the wafer from the printed circuit.
Hi, I had the same problem with a AOC LM727 monitor, the logo showed then a second of windows then it went blank, the menu would display very faintly, solding the coils fix the problem, this site might help:
http://www.starwars.myzen.co.uk/AOC-LM727/
Posted on May 31, 2008
Gracias, muy efectiva su recomendacion. lleva media hora funcionado y esta todo bien.
Posted on Mar 19, 2008
Hi there just fixed mine too , by soldering the contacts of the coils. they are on the powersupply board .two round rings copper wire.
thanx
Posted on Feb 16, 2008
I had the same problem. Screen goes black after few seconds.
So I tried to resoldering the two coils as suggested.
AND IT IS WORKING!!!!!!!!
great and thnks for the tip.
Posted on Jan 30, 2008
    Problem Solver:
The problem is the wire used to wind the coils. It's not insulated, but it's coated with laquer. If the factory doesn't scrape the laquer off the ends of the wires before soldering, then there will be a bad connection. The solution is to scrape the ends of the wires where they protrude thru the bottom of the circuit board, then resolder using a 15W soldering iron.
Posted on Feb 09, 2009
    President:
  • 949 Answers
ROLOLLMFAO, what kind of a joke is this. You buy a new monitor and you need to repair it because of the coils.
This can void any warranty, who in their right mind would do this.
Normal people would send it back to the company and tell them to fix it.
Start buying a real monitor, Acer, Asus, Samsung, LG, View Sonic, HP.
These AOC must be garbage.
Posted on Oct 29, 2012
Not work in 15min the display not will be on
Posted on Dec 27, 2009
Well I just resoldered both coils, and it Worked!!! I was about to throw away the monitor, but luckily found this page!
Thank You!
Posted on Jul 17, 2008
Perfect- worx great ! I was already looking to buy a 80LL15T-7-YSK in Japan ! But my japanese isn`t realy that good :-) !
Greatings from Spain
Posted on Jul 14, 2008
  • Hawkeye Oct 05, 2010
    Took me only 15 minutes to unsolder the inductance coils then sand down the 2 terminals on each and resolder and now it works flawlessly. I paid nothing for this monitor because it came free with a bunch of computer stuff that I bought for $30.00 off of craigslist. Thank you so much for fixya.com and the experts that are here to help others.
Hi guys
I had the same problem. First of all I tried to replace the big capacitor, but the problem remained.
Then I found and read those message considering these two coils and it WORKED for me too! Thank you so much for the shared info!
Dmitry
Posted on Feb 25, 2008
When the display goes to bank screen, mostly it is a dry soldering at the ring inductances/coils on the power supply board. Remove tin, clean the wire of the coil and resolder it. I have repaired many LM729's in this way.
Posted on Dec 01, 2007
Possibly a bad inverter, if that doesn't solve it probably a bad backlight. If you use the onscreen controls you should see an extremely faint image displaying the menus. That's the best way to check to verify it's not the panel itself.
Posted on Sep 05, 2007
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2013 | AOC 19" LED Monitor e950Swn Black
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Screen trys to show desktop, but quickly fades to
Since the power led button is on, the problem with your monitor is the that the picture board of your monitor has develop fault, that is why it tries to show your desktop and quickly fades away.
The picture board of your monitor is bad and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | ViewSonic VX924 19" LCD Monitor
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
3,804 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
