Question about Cuisinart SPB-7 SmartPower Work Top Blender
Cuisinart sealing gasket
I've forgotten where the sealing gasket (rubber ring) is placed in a cuisinart blender/food processor (7 speed) - does it go under the blades (cutting assembly) or above it? thanks,
  • Anonymous Mar 16, 2014
    cuisinart blender cannot unscrew blade
  • Anonymous Mar 27, 2014
    Old ronson blender rubber seal or gasket needs to be replaced
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
When trying to start my cuisinart smart power 7 speed, the on button will blink and then when I try to choose a speed nothing will happen. What do I do to make it work? Is it broken? I have only used it once and owned it for about a month.
Posted on Apr 13, 2008
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
How do you mount up a blender?
The rubber ring goes between the jar and the blade assy housing. It never goes under the blade assy, always to the jar.
Jun 01, 2014 | KitchenAid 5-speed Blender With Glass...
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
Misplaced manual. How to assemble Cuisinart Smartpower 7 speed electronic blender- Specifically need to know where to place the gasket.
Hello, W/D here.
You can download your manual here:
http://www.cuisinart.com/manuals.html
It is at the bottom of the page.
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Best regards, --W/D--
Jan 30, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Cuisinart SPB-7 SmartPower Work Top Blender Logo
934 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
