Apple iPod touch 8GB* MP3 Player - Black
Problem for Apple iPod touch 8GB* MP3 Player - Black
My ipod still won't do anything
By ceagirl24541 on Mar 19, 2009
It says itunes could not connect to ipod "ipod touch" because it is locked with a passcode.You must enter your passcode lock on the ipod before it can be used with itunes, but it won't let me enter the passcode lock
Comments:
Mar 19, 2009
- it won't unlock and i dont know how to restart it
Mar 19, 2009
- thank you very much
Clarification Request
Posted by mjjdesigns on Mar 19, 2009
Have you tried unlocking it before connecting it to your computer?
Best Solution
posted on Mar 19, 2009
Helpful)
mjjdesigns
Rank: Guru
Rating: 86%, 73 votes
If you're locked out, the only way back in, is to restore to factory default settings.
Try the following:
Make the iPod Touch go to Recovery Mode
If for some reason your iPod won't connect to iTunes, or whatever reason it is, you might need to make your iPod Touch into Recovery Mode. Here's how you could do that.
Makingyour device in Recovery Mode is irreversible. That means, once youexecute this, you can never get back your home screen until youcomplete the restore. So don't attempt this, because there's no room ifyou suddenly decides to change your mind. This method can also be knownas Manual Reset.
Step 1: Hold down the “Home” button
Step 2: Hold down the “Standby” button
Step 3: When it says “slide to turn off”, ignore it.
Step 4: It should restart with a blank screen. DO NOT LIFT THOSE BUTTONS YET.
Step 5: An “Apple” icon appears. You can lift the “Standby” button, but keep pressing the “Home” button
Step 6:Once you see a “connector” and an “iTunes” image (looks like when youjust bought it), that’s when it’s in Recovery mode. You can lift allthe buttons.
Perform a Manual Restore
Nowyou will need to perform a Manual Restore on it. The term "Manual", asthe name suggests, does not involve in using automated download viaiTunes. Instead, we are using iTunes do perform the Restore on the firmware we want.
See: Download the appropriate firmware
Step 1: Connect the iPod Touch, which is now in Recovery Mode
Step 2: Launch iTunes. iTunes will tell you that the iPod Touch is in Recovery Mode.
Step 3: Hold SHIFT while Left-click on Restore button. A file browser should come up. Select the appropriate firmware, then wait for the restoration to complete.
NOTE
You can also do this Restore if you want to downgrade firmware version 1.1.2 into anything else.
And viola! You should be kicked out of the misery, and start your hacking all over again.
Taken from this website.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Apple iPod touch 8GB* MP3
Questions and Unsolved Problems for Apple iPod touch 8GB* MP3
Do you recommend Apple iPod touch 8GB* MP3 Player - Black?
Answer
Answer
Help!! When I 'slide to unlock', I am presented with the number pad on my i-pod touch. I enter the... (More)
Answer
my new ipod touch needs a pin 4 it to connect to wi-fi iv got the ssid put iforgot the pin ?
Answer
after syncing comp and ipod touch i told it to transfer music and it took all music off the ipod
Answer
my ipod space has run out, it says about half of the space is other. I cannot remove or add anything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
