to change the tray that reports print from
it can be changed in service mode soft switch 323
change bit 7 to a 1 to print from tray 1
change bit 6 to a 1 to print from tray 2
bit 5 to 1 to print from tray 3
bit 4 to 1 to print from tray 4
bit 3 to 1 to print from bypass tray
The Transmission (TX) reports are set to print from a pre-selected drawer, meaning that if you change the orientation in the drawer, your reports will print in portrait.
You can also change the drawer that is pre-selected in the Administrator menu.
Unfortunately many of the "reports" on the 250 can only be printed on landscape. You may be able to change this in administrator (under the utility button) the code is 12345678 and select reports and then change the cassette that you want reports to come from.
Hi, My Konica minolta 210 printer gives me an error msg and it doesn't print and I have the driver...
(More)
Hi, My Konica minolta 210 printer gives me an error msg and it doesn't print and I have the driver to re-install the it and test but I couldn't remove the old driver (it doesn't show in the add remove program) can you help me please? Asma
Have a bizhub C353 conected to a network. Using a Windows domain. trying to scan to a network...
(More)
Have a bizhub C353 conected to a network. Using a Windows domain. trying to scan to a network folder..keep geing login failure. Have tested user accountpassword on another MFD (Canon) to the required destination and all ok, but cannot make C353 do this. ANy clues as to why I get the login error
I am having issues with the address book on my Bizhub 163, randomly the machine will just loose the...
(More)
I am having issues with the address book on my Bizhub 163, randomly the machine will just loose the addressbook. It doesn't seem to be related to anything that I can see going wrong (like power failures etc), when I turn the machine on and off (even for a long period of time) the addressbook remains, however sometimes twice in a week or once in 2 months the addressbook will disappear.
