-   Cannot read disk - but does spin and trys to read it. Tried cleaning the disks, - no help; tried cleaning the lens with 91% alcohol; - no luck. I don't see any sign of light coming out of the laser - but I only tried to indirectly look to see if I detected reflected light; - (although I now realize I should have tried to do this in a totally dark place - where I might detect the faintest reflection of light.)
Originally I cleaned the lens lightly with (maybe?) a dry or slightly alcoholically enhanced q-tip, and it worked for a few games - then the trick never worked again.-   Guest
Apr 27, 2008
-   Taken it apart, cleaned the lens over and over!!!-   QueenSarah
Nov 02, 2007
-   my gamecube always says can not read disk check booklet for more instructions.-   hot shit
Best Solution
posted on Jul 30, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
items-q tip, alchohal
take the q tip and dip it in the alcahol, then very gently tap the wet side of the q tip on the laser lens. then dry it off for a little bit. it worked for me
Just found this thread, **Never ever clean the lens with alcohol!** ever. most optical drive lenses are made of Polycarbonate these days and cleaning it with isopropyl alcohol will cause it to yellow and even crack. Use an *alcohol free* CD wipe wrapped around a Q-tip or use *alcohol free* lens cleaning fluid available from any opticians. If cleaning the lens *and disks* is no help make sure your disks are the same region as your cube, if they are then you are looking at a physical hardware problem. This can be as simple as a cable that's been jarred loose or as major as a dead drive/drive controller so where you go from here is down to whether you are confident enough to take you're cube apart or not? If you are re-post this to the premium forum, if not you need to check and see if your cube is still in warranty or not, it's not likely to be but this will depend where you are in the world, when you bought it and where you bought it from. Alternatively this may be a good excuse to buy a Nintendo Wii as the Wii will happily play your cube games and support your cube controllers/GBA connect cables/cube memory cards. The only Gamecube device the Wii will not support is the Gameboy player.
Clean eye with alcahol very gently or it could cause a crack in the lens then leave to dry for 10-15 mins then check if dry and try again hope this helps. :)
open the lid and clean the lens with a qutip dipped in a bit of alcohol, be very gentle because you can crack it Then let dry, if the problem still persist then you will have to adjust the lens.
when I turn my gamecube on and I have the game in it. it say's to turn off and read the instrution...
(More)
when I turn my gamecube on and I have the game in it. it say's to turn off and read the instrution manule.
I put my AV inputs on the AV 2 slots. Every thing Thing is connected in the Wii. I have an Insignia...
(More)
I put my AV inputs on the AV 2 slots. Every thing Thing is connected in the Wii. I have an Insignia HD TV. The input button gives several With AV as an option. Is that where I direct the input button to to play the Wii.
