Question about Brother ML-500 Typewriter
Left and right margins of typewriter on Brother ML 500 Memory
The left and right margins were changed by mistakes and now we cannot use the typewriter because the left and right margins are very close to each other
  • 125 Answers
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
    New Friend:
Thank You! Very helpful!
Posted on Sep 19, 2012
SOURCE:
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
Unable to move past left & right margins to reset
Go to broyher.com, click on support you will find a manual there.
DickyO
May 20, 2010 | Brother ML-300 Typewriter
How do I set left margin for brother model ML-300
Go to brother.com, click on support you will find a downloadable manual there.
DickyO
May 11, 2010 | Brother ML-300 Typewriter
My typewriter is stuck at the left margin. I
My guess would be that the left and right margins are set at the same place. Try resetting the right margin and see if that's the problem. I used to experience this a lot with kids playing with the typewriter.
Oct 15, 2009 | Brother ML-300 Typewriter
I bought a --brother AX-400 electronic typewriter at yard sale... please help me set left and right margins...
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Jul 18, 2009 | Brother ML-300 Typewriter
Change margin
Do you see the lmar and rmar above the number keys printed on the cover? Move the carriage to where you want to set the left margin Then hold down the ALT key and depress the corresponding number key under the lmar symbol. Repeat for the right margin.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 18, 2009 | Brother ML-300 Typewriter
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Feb 06, 2009 | Brother ML-300 Typewriter
Typewriter Brother EM-530
You have to position the carrier to where you want the margin using the space bar or backspace key. Once you get to the desired position you must press either the left or right margin button depending on which one you want to set. You may have to use the code button together with the margin button. Lawrence
Mar 03, 2008 | Brother ML-500 Typewriter
Unable to set margins
To set the Left margin:
1) Move the carrier ro the place you want to set the left margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current left margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[L MAR(4)]. The left margin is now set.
To set the Right margin:
1) Move the carrier ro the place you want to set the right margin by using [SPACE BAR] or [BACKSPACE]. If you need to move outside the current right margin, press [ALT]+[M REL (3)]
2) Press [ALT]+[R MAR(5)]. The right margin is now set.
That is directly out of the manual. I will upload the manual to FixYa, and you will be able to view it from the ML-500 Typewriter's product page: http://www.fixya.com/support/p131634-brother_ml_500_typewriter
-John
Feb 06, 2008 | Brother ML-500 Typewriter
Brother ML-500 Typewriter Logo
473 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
