Question about Intel D850MV Motherboard
Intel D850MV motherboard
I have Intel D850MV motherboard with two 256 MB and two 128 MB RDRAMs, AGP video card with 128 MB on-board RAM, Samsung 40 GB HDD (ATA) and DVD R/RW drive. Upon plugging the computer to the power source it powers up before the power button is pressed. The power LED, HDD indicator LED and two LEDs on the motherboard light up. The cooling fans on the processor and inside SMPS start rotating. But there is no activity and no display on the monitor. There are no beeps. The power switch and the reset switch do not function. However if power switch is kept pressed the computer shuts down. The CPU and video card heat sink and hard disk become warm. The DVD LED lights up initially and drive door can be opened and closed. What could be the problem? I am located reasonably far from authorized service outlets. Any advice useful for my local service person will be most welcome.
    Novelist:
  • 231 Answers
Hi another test is to first disconect extras such printer etc, then remove all your Ram chips, replace these one at a time in slot one, test your boot up, if no luck remove that stick and try the next one and so on. This way you eliminate a faulty RAM stick. it also would not hurt to have a close look at the capacitors on your board. they are the round tube like things sticking up everywhere, if any are bulging or have evidence of leakage at the bottom then discard your board and start anew.
Posted on Aug 17, 2007
    Problem Solver:
  • 9 Answers
This is Old problem with this mother board, Check u r dummy ram stick, if its fixed properly, and if possible get bios upadates, Check u r smps, it should be above 400watts. this can probably solve your problem.
Posted on Aug 16, 2007
  • 102 Answers
If you hear no beeps and the led lights, and the fans stay on after striping all the components from the motherboard except for the cpu, and power supply, you have either fried your motherboard or your cpu. Its impossible to tell without more testing. I'm sorry but you either need someone to test it or you can buy a new computer (thats what I did). For about USD $300-$400 you can get a brand new computer with 500mbs of ram, 120gb hard drive and a 3 ghz cpu. If you look around you can get an even better deal.
  • Mark Rogers Aug 17, 2007
    Ok, either I have bad English or is that what I have already said?
SOURCE:
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Sep 27, 2014 | Computers & Internet
Increase graphics from 96 to 128
If you have insralled the correct video driver and you cannot increase the VIDEO RAM then it is not possible to increase the bit color from 96 bit to 126 or 256 bit color.
The only way to have a higher bit color is to install a new graphics card that supports up to 256 bit color (this video card will have large cideo RAM).
Mar 09, 2012 | Intel Desktop Board D865GVHZL Mainboard -...
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
    Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
    Hope this helps.
    Nov 09, 2009 | Intel D845PESV Motherboard
    USB driver 2
    Can you be more precise? You don't need USB driver for this PC...
    Jun 25, 2009 | Gigabyte Computers & Internet
    Memory capacity
    Four RDRAMS slots, that support up to 2gb
    http://download.intel.com/design/motherbd/mv/ProductBrief.pdf
    Hope this helps,
    David
    Mar 11, 2009 | Intel Computers & Internet
    Laptop
    here are some details below find the right one and take it
    Model No: TM 2403NWXCi
    Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    RAM: 256 MB DDR2 400 RAM
    HDD: 40 GB
    Optical Drive: DVD-Rom/CD-RW Combo Drive
    Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
    Graphics: Intel GMA900
    Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 6-Cell Lithium Ion Battery
    O.S.: Linux
    Warranty: 1-Year Global Warranty
    Price: Rs. 27,999*
    Model No: TM 2424NWXCi
    Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    Model No: Aspire 5002NWLMi
    Platform: AMD Turion 64 ML-30 (1.6GHz)
    RAM: 256 MB DDR333 RAM
    HDD: 60 GB
    Optical Drive: DVD-Dual Double Layer drive
    Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
    Graphics: N.A.
    Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
    Weight: 2.9 KG
    Battery: 8-Cell Lithium Ion Battery
    O.S. : Linux
    Price: Rs. 37,999*
    Model No: Aspire 5004NWLMi
    Platform: AMD Turion 64 ML-34 (1.8GHz)
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
    To u my friend
    nothing much buddy ...
    HDD: 40 GB
    Weight: 2.38 KG
    O.S.: Linux
    Price: Rs. 27,999*
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 37,999*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Model No: Aspire 5502ZNWXCi
    Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
    HDD: 60 GB
    Optical Drive: DVD+CDRW Combo Drive
    Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
    Weight: 2.38 KG
    Battery: 6-cell Battery
    O.S. : Linux
    Price: Rs. 40,499*
    Model No: AS 1641NWLMi
    Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
    RAM: 256 MB DDR2 533 RAM
    HDD: 60 GB
    Optical Drive: 8X DVD-Dual Double Layer Drive
    Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 4-cell Battery
    O.S. : Linux
    Warranty 1-Year Global Warranty
    Price: Rs. 42,499*
    Apr 14, 2008 | Computers & Internet
    My hardware upgrade
    all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
    Mar 18, 2008 | Computers & Internet
    Video card upgrade
    Needs specs of your board.. Model number
    Nov 13, 2007 | Shuttle AV41P Motherboard
    Intel D850MV Motherboard Logo
    166 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    Ekse
    Joe Negus
    Joe Negus
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
