Question about Hitachi 43UWX10B 43" Rear Projection Television
Screen flickers off and on
Tv similar to picture but not hd or 3d.... soon after turning the set on the screen flickers off and on for a while then stops and starts again after a few more minutes
SOURCE:
  • 4234 Answers
SOURCE: three d
There is a problem with the convergence circuit that the focus won't fix. You will need to either resolder the pins on the convergence ICs or replace them. These are large black ICs attached to a heatsink and are marked STKxxx. Resolder first. If that does not resolve it, replace the ICs.
Dan
Posted on Mar 17, 2008
Ecollier2012
  • 3459 Answers
SOURCE: when i turn on tv the screen is turning green
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Posted on Jan 29, 2009
phil_frye
  • 295 Answers
SOURCE: Picture is fuzzy for the first few mins after turning on
This may be an issue with your color wheel where it isn't spinning up to speed at first but finally does after the 2 - 10 minutes. Fairly common in DLP TV's.
This could be fixed by a qualified Hitachi Servicer.
Blessings,
A/V Media Tech Guy
Posted on Nov 25, 2009
welcomejee
  • 10594 Answers
SOURCE: fuzzy picture...started when first turned
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Posted on Apr 18, 2011
Ecollier2012
  • 3459 Answers
SOURCE: Power light remains on, hear sound like set being turned off, then screen goes black, 10-30 seconds later hear set turn back on and screen is fine again. Repeats randomly every few minutes to every 1
This is a common problem and a fairly easy DIY fix. You can get the parts from www.TvRepairkits.com
Posted on Mar 19, 2012
I have anew Samsung 55 inch model code ue55h6500akxxu but it will not store my settings as soon as i turn tv off an on again it goes back to custom settings
This is from an article I found online:
"It's likely that the television is in Shop Mode. The symptom would be that your settings are defaulted back to the out-of-box settings?
Try holding down the Menu button on the TV (Not remote) for 12 seconds.
OR
Try pushing the volume button up once, let go, and then hold down the MENU button for about 12 seconds.
You might see the screen flicker, and that's okay. Once you've done that, you should be able to program your settings and they should stay.
--HDTech"
Feb 02, 2015 | Samsung Un55c6400 55 Inch Led Hd Tv - Free...
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Samsung HDTV model HLR5067W screen flickers when some commercials play other commercials are ok when viewing. Could this be my HD set top box or a cable?
If the TV works well with your dvd and regular programs there are no issues and the flickers due to commercials can be due to excess signal strength or even poor control from the set top box.
Try with another set top box to confirm as some of them can process noise which can cause this issue.
Nov 15, 2011 | Televison & Video
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
My LG HD T.V wont let me play my playstation
Maybe you've got a wrong menusetting in your Playstation.
Kind regards,
Gerard
Jan 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Mar 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
