Question about Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony 19" Power button does not stay on tv cuts right back off
  • Neesie Aug 16, 2007
    My television is 19" Sony but I'm not sure about this green light that you are referring to where is it at on the television?
    President:
  • 3,130 Answers
How many times does the green light flash? This green light can tell you the area where the problem is but it will not tell you what is bad.
Posted on Aug 16, 2007
  • Larry  Dillon
    Larry Dillon Aug 16, 2007
    It is the timer light I am talking about and how old is this TV set.
SOURCE:
Is there a reset button on the back of a sony play station 2 or power button???
If you are talking about the PS2 "FAT" or "SLIM"? The fat has a switch in the back that cuts all power, but the slim stays in standby mode unless you unplug the system.
Apr 29, 2014 | Sony PlayStation 2 Slimline Console
My sony 52" keeps cutting
You may have bad power and your TV may be reacting to voltage drops or spikes. Is your TV powered through any kind of conditioner, surge supressor or filter? If not, you should consider getting one even if its only a $100 item. Stay away from standard or computer power strips though. Make sure it is not overheating and you have plenty of cooling space around the TV both to the sides and back, if it starts to overheat it will shut down. Or it could be a panel or internal board error. You'll need to get Sony tech to diagnose the problem. Are you getting any blinking lights when it shuts down? these are a code for the techs to let them know what to start looking at .
Jan 07, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My insignia model ns-ltdvd26 will cut off on its own. will turn right back on but will only stay on for a few minutes then cuts back off
Power supply board is the cause.The power supply board is shutting down,not giving the right voltage to the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 12, 2010 | Insignia NSLTDVD26 LCD TV
The TV was working fine and it cut off. I turned it back on and it will stay on for 2-3 seconds and cut back off. The red button seems to blink once.
consider looking at your manual for replacing the projection bulb. They don't last indefinitely and depending on how many hours of use yours gets, the bulb may fail when it heats up. My Sony projection tV had very similar sysmptoms and no indication of anything else wrong, If your tV is a few years old and gets good use I would at least think about it. My Sony was easily user serviceble and cost less than it would have for a service call.
Sep 30, 2010 | Panasonic PT-47WX53 47" Rear Projection...
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
How to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Mar 10, 2008 | Televison & Video
Tv cuts off and on.
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Sep 06, 2007 | RCA D56W20 56" Rear Projection Television
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
