Question about PSC QS6000 Plus Handheld
Bar scanner shoots once and then locks up
Moved the scanner to another workstation and now it won't work...shoots once and then nothing..
  • haney737 Dec 07, 2008
    It works on XP Desktop, does not work on Vista Laptop. It shoots once does not put data on screen. Vista says' USB Device not recogonized'.
  • rvaskx Feb 01, 2009
    I have a QS 6000plus that I just can't get to work with windows vista any help  would be appreciate,  Thanks
It finally just started working a few days later. I don't know what fixed it. Maybe Windows Vista just finally found the drivers?
Posted on Jan 27, 2009
The precedent model was using the same cable as the keyboard, the new one is comming with his own cable. I had exactly the same problem when I tried to change the scanner only. I had to use the new cable.
Posted on Sep 18, 2007
    Problem Solver:
  • 20 Answers
If it was ok with your former workstation then It must be have something to do with your new workstation, check out carefully the port that connected to the scanner.
Posted on Aug 24, 2007
SOURCE:
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
The scanner won't move. I tried the lock button and it is not locked. Light comes on and paper goes through but scanner doesn't move.
if the scanner is not locked, you can try pressing #*C* then enter 14 and press start, if it is not resolving your problem you need to replace the carriage motor mcu pwb and the power supply pwb respectively.
May 18, 2011 | Sharp AL 1631 Copier
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
Scanner will not unlock
My X5150 did the same thing even after unlocking. I finally took the top part off (you'll have to remove two small screws on the top back under the scanner cover and then kind of pry the top loose) and found that the belt had came loose from the scanner bar. I had to push it back into the little slot on the end of the bar. Once I did this, it works perfectly with no errors.
Apr 25, 2010 | Lexmark X6170 All-In-One InkJet Printer
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
Scanner making clicking noise
I just got that scanner back, L1 error code on a Sharp copier. Means the scanner can't move quick enough to satisfy the specs.. Removed the lock, not needed. Oiled the bar, scanner works ok now. Will look for Triflon lubricant, my favorite. Will check with local repair shop for recommended lubes. That light sensor switch is not necessarily on your unit, but I see them on a lot of machines. Sometimes it's just a little tab or button, hard to find. Check the freedom of your scanner bar. Temporarily loosen the drive if you can. The bar must move freely.
Jul 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Continually scanning
Make sure the lock switch is in the unlocked position. The lock switch is on the bottom of the scanner. It sounds like something is preventing the scanning bar from getting to the home position. If the scanner was somehow locked with the scanning head being out of the home position, then the result would be what you describe.
Jun 25, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan 5000F - Scanner bar is stuck
hi all;
i fixed it by taking the thing apart, pushing the scanner head (the block that is stuck-- that normally moves) back to the starting position. Make sure its snug at the end, a little bit off and you'll be putting it have to take it apart and back together a second time. There's a mirco swtich in there somewhere, and you need to make sure its pressed...
reconstruct, and hey presto, a working scanner! this also worked for my epson 1250 that got stuck once.
Easy as a section of gateaux.
Oct 04, 2007 | Canon CanoScan D660U Flatbed Scanner
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
PSC QS6000 Plus Handheld Logo
591 people viewed this question
Top PSC Computers & Internet Experts
Thomas F. Schneider
Tom Chichester
Terry
Terry
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
