Question about Sony PlayStation 2 Slimline Console
Ps 2 freezing up
Somtimes it freezes up and then works. somtime it says disc tray open when it isnt somtimes just goes to browser sreen only 1 year old help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
There is no need for laser to be adjusted because you shows that somtime it says disc tray open when it isnt. The PS2 has two tabs, one in the lower right above the power button (point A), and one in the upper left below the lid hinge (point C). As long as both tabs are depressed, the PS2 will think the lid is closed. Check FIG-1 1) Point A is externally accessible through the hole which a lid tab usually goes through. 2) Point C can only be easily accessed by opening the PStwo case. 3) Point B, the disc brake, can be ignored for all intensive purposes. Check FIG-2 1) The far sensor tab is what we're interested in. Check FIG-3 1) A closer look at the far sensor, which needs to be taped down or changed. After checking all this thing your problem will be solved.
Posted on Aug 23, 2007
  • 85 Answers
I would say that the laser needs to be adjusted. I am sure you can find someplace that can give you the precise way to adjust the laser, but other than that you may have to send it in to get repaired. I also know that if it is the slim it is hard to open up, because there is a connection that you may break if you open it wrong.
Posted on Aug 17, 2007
6ya staff
SOURCE:
Cambridge Audio AZUR 840C Transport Jamming when disk is loaded
The above comment is complete and utter nonsence !
Here's what you do . Take the lid off , take off the top of the cd transport marked "CD 1 Low Jitter Compact Disc Transport" held on with 2 screws , rince it under warm water (its made of plastic) and refit . Its a build up of dust . Yoy will have to do this every 2-3 years . P.S Leave on "stand-by" because you will do more damage to the circuit boards by cutting the power continually .
Sep 15, 2012 | Cambridge Audio Azur 840C CD Player
Can the struts or shocks freeze on my 2005 equinox? It started a couple of weeks ago when the temp went below freezing.
Yes if they are leaking and you go to a car wash and then the temperature goes below freezing. It happened to me. Car started rocking all over the place because water got inside the strut and then froze solid overnight
Jan 10, 2010 | 2005 Chevrolet Equinox
I have disc read problems.
I do hear that the controller card on that revision of PS3 can have failure issues... right now I'm waiting on a new bluray drive assembly for a CECHE01 because of, basically, the very same problem. This eBay seller(lives on the other side of the US from me) seems to know a good bit about these issues, and even provides his phone number for tech support. Search under his store for: CECHE01
http://shop.ebay.com/arcphiltechrepairs/m.html?_nkw=&_armrs=1&_from=&_ipg=25
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 reads disc somtimes then freezes or trys to read then error 80010514
i think your laser is broke
if your insured take it to the shop where you bought it
if not new lasers are around 150-180 pound
hope i helped
cya
May 01, 2009 | Sony Playstation 3 (PS3) Console
Play station 2 has two disc stuck
the disk tray gets jamed alot u can pry the whole tray open with a screw driver or plyers the ps2 will still read the disk even if you pull the tray open it should realine itself and open and close you may pull off the front part of the tray but if you dont care about the apperence and just want it to work this solution works most of time
Jan 07, 2009 | Sony PlayStation (PS) Console
Game takes ages to Load, then freezes.
make sure your discs are clean then try again if same occurs put a cleaning disc into your console this will clean any unwanted dust particles if same occurs again you may have a problem with your laser that reads discs i had same problem
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Acer Aspire 4720z Freezing Alot
increase the virtual memory and tell me whats the ram?
try and run 3 softwares from www.gur.in from the download section and run them in the same sequence
1) malaware bytes
2) dial a fix
3) superantispyware
Nov 01, 2008 | Acer Aspire 5004WLMi Notebook
Philips lx3600d
You have a software problem. When I worked at Philips CEC before we closed I did a lot of those. I have the same unit also. But when we left I didn't take the upgrade disc so I'm stuck as well as you are. I just live with it untill something else happens then I'll deep six it.
Apr 11, 2008 | Philips LX3600D System
X box 360 problems
is it placed on its side (the hdd facing up) that might be why the disk tray is not opening.
Mar 17, 2008 | Microsoft Xbox 360 Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
