Question about Sony Handycam CCD-TRV308 Camcorder
Error 3155 I have a sony handy cam ccd-trv308 h1-8----when i put a tape in --i get a error of c3155
    Champion:
  • 287 Answers
Have it cleaned by video tech service. might be all it is or could need some tension adjustments. The guy there is super cool.
Posted on Sep 18, 2007
SOURCE:
Error 32:30
This could be a Capstan problem, it is common on lots of cameras like yours, have you run a cleaning cas tape through the camera of late? if not get one from your local shop and put it in and leave it on record button for 30 sec then run it on play 30 sec.
Jun 07, 2010 | Sony Handycam CCD-TRV308 Camcorder
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony Hi8 CCD trv308 NTSC making noise during recording that is audible on playback. Sounds like some moving parts related to turning the tape are not moving as smoothly as they should. Is there anyone...
I had this problem with one of these otherwise very cool cams that I inherited. Something was rubbing on the case of the cassette making a usually faint but audible grinding noise. It is hard to see unless you push the tiny lever on the side of the cassette and flip up the plastic flap that protects the tape. There was a small visible gray grind mark on the center of the case. Now when I buy a new tape I flip open the cassette and carefully scrape away enough plastic on the center of the cassette where it rubs (you can run it a bit and it will grind and show you where) so there is clearance. It worked!!
May 01, 2009 | Sony Handycam CCD-TRV308 Camcorder
TAPE WILL NOT EJECT BLEEPING AND FLASHING C;32;11
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Cheers
Oct 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Handycam says C:31:22
error 31:22 means camera mechanism has error in take-up reel section and micro processor isn't receiving reel signal so it shuts down playback/ record function immediately. look into take-up reel section of mechanism.
Sep 11, 2008 | Sony Handycam CCD-TRV308 Camcorder
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV128
You have stated the problem yourself - 'I rarely use it'. The electronic and mechanical components within need regular use to stop them failing.
Jul 15, 2017 | Sony Handycam CCD-TRV308 Camcorder
CCD-TRV308 - TAPE DOOR WON'T OPEN
depends where the tape is located if it's still wrapped around the head i would recommend taking it in if it's inside the cassette you can have to take the door off and see if it pops out.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
Oct 17, 2007 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
108 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
