Question about OKIFAX 4580 Plain Paper LED Fax
Toner sensor error - OKIFAX 4580 Plain Paper LED Fax
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
May 18, 2014 | Canon ImageRunner 2270 | IR2270 |
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
Error E00024-01
this error stands for toner sensor fault or disconnected connector on toner assy or on dc controller.
You need to check the sensor on toner hopper, on toner station and on dc controller. after reconnection of mentioned things, if the error is still there you need to replace the toner detection sensor on toner/developing assy.
Hope that helps!
For service manual, if you gonna to try and fix it by yourself, you can write me on emma.servis@gmail.com.
Apr 29, 2011 | Canon imageRUNNER 4570 Copier
Error 000020-000 in photocopier iR3025/3028
These is error code related to toner station trouble. It could be toner sensor fault, broken parts in toner hopper,...
the book says:
E020 The path between the sub hopper and the developing assembly is clogged with toner.
0000 The developing assembly toner sensor detects the
absence of toner, while the sub hopper toner
sensor detects the presence of toner. With the
developing clutch turned on, the hopper
feedscrew motor is rotated for 1 sec intermittently
194 times; still, the developing assembly toner
sensor does not detect the presence of toner.
Replace the developing assembly toner sensor.
Replace the sub hopper toner sensor. Replace the DC
control PCB
Aug 12, 2010 | Canon iR 2016i Black and White Copier
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
OKIFAX 4580 Plain Paper LED Fax Logo
16 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
