I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
