Motorola Mobility EQ5 Bluetooth Headset Logo
A
Anonymous Posted on May 23, 2013
Dead battery eq5 - Motorola Mobility EQ5 Bluetooth Headset
2003 chevy silverado body control killing batteries
you lost DC power, the main battery is dead.
no list of good and bad,just bad.
DC power goes to VAST things, in all modern cars even 10x more.
so all things good and bad matter.
engine dead. will not crank or start or run
head lamps dead, or dim, key on and off.
blower dash (heat?) dead. on all speeds for sure high.
dome lamp dead
windows dead, door locks dead.
what to do, when DC fails for sure the engines stater motor dead.
making car useless.
  • check fuses first.
  • check battery voltage 12.6vdc rested never 10v or below.
  • jumper cable crank start the dead engine,
  • runs now, if yes check battery again, 13v to 15vdc below is bad dead alternator (or its fuse, ore belt fell off/slips)
  • a bad battery ca n cause modern cars ALternator to go off line to prevent battery rupture (flying acid doomed)
  • scan the car key on,see DTC errors like (fuse blown or battery dead errors)
  • that is it for this far, a voltmeter finds it. easy used.
  • one more, if IMMO lamp is not happy ,engine can not run.
2007 jeep gc won't start. Lights, battery all Dash lights had been acting strangely before this happened. Turned the car off, Swapped AC relay with starter relay and nothing.
i guess you mean starter is dead, and all lights dead.
pointing to....
the battery is dead, did you jumper cable start it?
if that works the battery is bad, dead or only dischanged.
if that dont work make sure the battery cable lugs are cleaned.
no rust on cable ends( that green junk there that all cars get)
if the head lamps die (they work key off so...)
then the battery is dead, or rusty lugs.
if battery is dead, charge it. using a charger.
When stalled car will not start again for some time and battery seems dead. What is this?
that is because it is dead?
that key dead thing is called NO CRANK, not no start.
no car starts unless cranked, or push started or gravity started,
so its a NO Crank issue,
and the stalls, well if the battery drops below 10v the EFI system
stop working just like your lap top does, or CEL phone
and for same reasons.
most folks do a jumper cable crank next. like the AAA tow truck man does first, and for good reasons.
this proves what is wrong,
1: battery was dead (car cranks now)
2: starter dead. or key line dead, if not. cranking now.
my guess is its #1
if battery was dead, then it is
  • bad battery.
  • only discharged, so why not charge it?
  • or phantom drains, (over night parking battery dies)
  • or alternator is dead, (chargelight glowing? test alt.
Problems to pair motorkr EQ5
Is the EQ5 in pairing mode? What happens when you search for the speaker?
Mark
Motorola Support
Battery dead open boot
its should still open even with the battery dead all doors should open manually with the battery dead
How to change battery
You cannot change battery for that device. The battery is already placed and sealed inside. If the battery runs out, please charge it using the cable provided in the package and connect it to the power outlet.
Trying to overhaul/rebuild a Hardin STAR HOC 8-4 7.9" f/4 Newtonian reflector with equitorial mount. Has been sitting out in the desert for who knows how long and is covered with fine desert...
You will not find any instructions for this particular mount and tube.
However here is a video on Telescope mirror cleaning-- and a web site on disassembling an EQ5 mount which is similar to your moun.
http://www.youtube.com/watch?v=9Y8xFnXFVGQ
http://www.astronomyboy.com/cg5/
I paired the EQ5 and my 1st generation iphone and it doesn't work. Audio still in the iphone and nothing in the motorola EQ5
Make sure you establish the stereo A2DP link prior to firing up the music player on your phone. You should see some sort of indication about that link on your phone' screen (my WinMo phone shows a specific icon in the task bar). Besides, the EQ5 should be flashing in green every 6 seconds, thus indicating that the A2DP link is active.
Please, let me know if you need further informations.
Hope you are able to sort your problems out soon.
Regards, Carlos
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
