Question about Nintendo DS Console
Nintendo ds I have replaced the case on my ds and now it wont turn on, it just makes a faint clicking soumd when I push the power button.
  • voyger Aug 16, 2007
    I checked all the connections and found that I had to push the ribbon cable from the top screen further into the connector on the mother board.
    Now it will power up OK but the two screens come on white and stay that way occasionately there are some colored vertical stripes on both screens but otherwise no picture at all.
    The sound and touchscreen are working and you can actually load up a game if you know the right places to touch on the screen, it's just not giving any picture. have you got any ideas.
  • Anonymous Mar 24, 2014
    wont turn on it makes a flicking noise when i turn it on
  • 944 Answers
First remove the new case and see what you get - if it all works fine then the case must be pinching a cable or pressing on something it shouldn't. Check the unit with AC only or battery power only. The faint click is probably the power switch membrane clicking across - probably indicating that the switch itself is fine - but check at least visually and with a meter if you can. the most likely causes of the problem if removing the case again does not get it working are; Loose connector - probably where the screen hinge is, or where those cables connect to -check anything that you could have moved. Is it an official original case? some cheap copies may be badly fitting, although I found no info on any problem like this so far. If you have a card inserted, try with a different one or without one. check nothing got in the card slot and no pins are bent - especially if you just put a card back in after replacing the case. Especially could be problem if your DS was set in Auto start-up mode before. Possibly unconnected to the case change, the power supply or battery could have failed. Check through this link and see if it helps identify if that is the problem. Do you get any power or charging lights? http://www.nintendo.com/consumer/systems/ds/trouble_power.jsp nintendo do not recommend it, but it may be worth removing and reinstalling the battery in order to reset the unit. proceed with care. Here is the link to the manual if you need it; http://www.nintendo.com/consumer/downloads/ds_english.pdf Hope this helps - please post back with more details :)
Posted on Aug 15, 2007
SOURCE:
How to erase date on animal paradise ds
Usually a hard reset of the game will (Works for most DS games) Before powering on the game, or in the case of DSI or 3DS before clicking on the game icon. Press hold the "A," "B," "Y," "X," "R," and "L" buttons simultaneously while holding these down turn on the game or press the game icon.
Oct 04, 2013 | Nintendo Ds Animal Paradise Wild
DS Lite
The green light is blinking, no red lights or anything else? The fuse is good as well correct?
Thanks,
Lee
Jul 19, 2008 | Nintendo DS Lite Console
I turn on my ds green light comes on bottom screen flashes then turns off
    • 1 Turn off the Nintendo DS, and place it on the charger. Leave the device for 45 minutes to allow it to gain a full charge, and then power it back on. Weak Nintendo ds lite batteries may cause screen flicker.
    • 2 Turn off the DS, and remove all game cartridges. Turn the system back on to launch the main menu.
    • 3 Click the small sun icon to open the brightness menu. Adjust the brightness level using your stylus. Turn it up to max to improve back lighting.
    • 4 Check that the Nintendo DS is open and in the locked position. It must be open to its default position to operate properly.
Apr 15, 2012 | Nintendo DS Console
I accedentaly pushed a xrong button when I was choosing my language. I pressed the french button when I needed english.
Slide Power
Press "A" when you get to the Nintendo DS bit.
Go the the bottom icon of the DS.
Press The first button you can see (Above the Back Button)
Press the button which looks like a round cake.
Click on "English" or "Anglis"
Dec 31, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Problem
That sounds like your DS lite have a lose circuit part rolling inside so thats why it cant turn on.
You need to open the console, recover the lose part from the inside and resolder it in its place (usually near the power switch, marked as L2). That should fix the problem, if not then you might have blown fuses, lose screens ribbon cables or broken LCD screens. All of these repairs are discussed in other questions here.
Regards
Nov 08, 2008 | Nintendo DS Lite Console
Power problems with DS LIte
DID YOU TRY A DIFFERENT BATTERY SOPHIE6j?YOUR BATTERY COULD BE DONE
Sep 01, 2008 | Nintendo DS Lite Console
NINTENDO DS PROBLEM
If you havnt had your DS very long you can easily get a replacement or sent off for repairs if not find a repair shop, they can practically do anything
Jack
Apr 19, 2008 | Nintendo DS Console
Nintendo ds lite
The switch is broken. This is a common problem if the shell case has been removed or if someone simply pushed way too ******* the power button. A new button can be purchased on ebay for under $10. Some soldering and desoldering will be required. The DS Lite is breakable when taking it apart so be careful. You can also send it to a guy like me for a fee and have it fixed or sell the broken unit to someone like me that fixes them.
Mar 29, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
