posted by titawee on Aug 15, 2007
IP : 192.168.0.1
Router is okay when connected to the desktop, but the wifi ready laptop can't connect to the router. Followed the setup wizard in installing the router to the desktop, do I need to install the same info on the laptop? The laptop can't recognize the router. Should I reset the router and start all over again? Should I change the wireless setup encryption or leave it on a default mode?
Best Solution
posted on Aug 16, 2007
Start with the simplest answer first so make sure the laptop's WiFi is turned on.
If you have set the router to provide a closed network your laptop will not see it automatically and you will need to enter the WiFi network settings in network setup. if you are using Windows click start, click control panel and click network, on the left hand sidebar you will see "Setup a Small or Home Office Network", follow the wizard and you should be able to get connected. If you are using Mac OS X click the Airport icon on your menu bar, click "other network" and enter the SSID, select the encryption type and enter the network key (password).
Lastly make sure that if you have chosen to use an access control list you have entered and allowed your laptop's MAC address in the list before trying to connect.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for D-Link DI-604 4-Port Cable/DSL Router
Email this problem
Email this problem
Can you Help with these Bridges problems?
D-Link DI-604 4-Port Cable/DSL Router...
....dead port?...........
I have a problem with my Dlink... Answer This...
Repair Service
Find Bridge Repairman Near You:
