Question about Sony PlayStation 2 (PS2) Console
Ps2 console Hello I well to seeing if they can help me him(her) dire ue step I stop in pause my ps2 entnoces when volvi the game was frizado enonces when I gave him to restart, I do not stop him(you,them) to see you eat ningun neither game nor nothing, they say to me that it is the video that is bad ... that I can do?? Help me that I am desperate??
  • 85 Answers
I am going to say to check to see if your CD has any scratches on it. Check both sides because it won't work if the cover is scratched as well. Open it up carefully, if it is the slim, don't open it, it has a connection you can sever. If it is not open it up, open up the dvd tray and then with a qutip dipped in a bit of alcohol, clean the lens very carefully.
Posted on Aug 17, 2007
Clean inside eye with alcohol
SOURCE:
What is a PS2 format disk and where do I buy one.
Hello thompsonfc,
A PS2 format disk is basically any game disc that is created for use in the Playstation 2 console. Any PS2 game that you buy in the region where you bought your console should be compatible. Certain PS1 games and PS2 games from different regions will cause this error to display. Send a reply if you need any further information or please rate this solution if you found it helpful. Thanks!
Edward
Aug 22, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 has stopped working!!!
spindle motor went bad it sounds like. Open up the ps2 and inside of there, you'll see a ribbon for the drive, take it off of the board and then reseat it.
Now put the top back on and try the drive again. If it still doesn't spin then the drive will need to be replaced.
Jan 06, 2010 | Sony PlayStation 2 Slimline Console
Ps2 wont play DVDs
Your PS2 laser is wearing out. When the laser starts to go, first games will skip... then eventually the PS2 will stop reading DVDs altogether. If you keep using it to read CDs, it will eventually stop reading those too and the laser will die altogether. Here's a website that will help you identify your PS2 model, show you how to replace the laser, and they sell parts and do repairs too
http://store.richspsxparts.com/slps2direerl.html
Oct 05, 2009 | Sony PlayStation 2 (PS2) Console
How can i get a playstation 2 games and how can i copy to my cd
Are you talking about backing up your PS2 games?
For that you can use many different programs (Alcohol 120%, Nero, Magic Disc< etc.)
But this is the catch, you can back them up and burn them, but you can't play them. You see, Sony burns their games in a special way, the disk (PS2 game) tells the console, Hello I'm a PS2 game, but your backup would say, Hello I have this in me ("this" is what ever game). But ye you can play them, but for that ou woud need a mod chip. Mod chips void warranty and if not installed correctly, can ruin your console.
Anyways, hope this helps.
Jul 14, 2009 | Sony PlayStation 2 (PS2) Console
How do u pause on sims 2 PS2
L1 only pauses the movements of the characters. I believe you need to press the actual start button located in the mid-center of your Sony analog controller.
Jun 08, 2009 | Sony PlayStation 2 (PS2) Console
Explain Pause for cheats PLEASE!!! Sims 2
ok. 1.Put the game in. 2.Select whatever gameplay. 3.When Loaded, press the START button located in the center of the controller. 4. Press(not hold) the selected buttons you need to press for example: R2(press R2) Triangle(press triangle) etc.  5. Now do this as fast as you can. If you can't do it fast, either get somebody who is fast, or practice. 6. I think on Sims 2 they make a noise when you get it.
Jul 07, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 problems
The PS2 Works fine right correct?? If it does and you want to fix the Laser do the following :
Step 1 Turn off the PS2 if on.
Step 2 make the PS2 lie down on its back where the PS2 logo is not seen.
Step 3 Take off the Rubber Squares which are located from all 4 corners and take out the screws using a screw driver.
Step 4 Take off the lid of the PS2 after the screws are taken out.
Step 5 near the light of the PS2 were it shows the Green and blue light is a box where the PS2 disc runs.
Step 6 screw the top of the box and you should see a disc if not taken out and underneath the disc is the lens use alcohol and gently wipe the lens with a Q-Tip after doing so put the lid out of box back on and open the disc drive and put a game in it should work or just get a new PS2 Slim.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 slim 77004
Problem : Over Heating of your console. try to check the ps2 cooling system. what the FAN/ blower is work?
If not, there is some fuse protection is burn. pls describe your Motherboard types... Hope this be of some help/idea. Pls post back should you need additional information.
^_^ im from Java..
Dec 05, 2007 | Sony PlayStation 2 (PS2) Console
My game freezes at the same spot every time
First step should be to change the game by the new one (or clean the disc). If this still not help please advice.
Apr 03, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
