Can someone help me figure it out this problem? I am using a linksys router (model no. HPRO200). It is an old model and wired linksys router. I am also using a motorolla cable modem. FYI, My internet provider told me that they used a dynamic IP address.
I have no clue why one of my computers cannot access an internet. My first computer that is having the problem is telling me that there is no internet connection.
I will really appreciate if someone can let me know what the problem is.
if you are using dynamic ip address makes sure in that computer that are not connecting has no static ip address, go to my network places and hit propertis, and select tcp ip4 and hit properties, make sure its selected as dynamic not static, if this not working this means, there is cable problem, or network card problem. or try to change the port from the router could be the router port is bad.
On your computer having the problem, we need to determine if the connection to the router is good. To do this:
Click START > RUN, and type cmd (hit enter)
A black window should come up. (known as a command prompt)
within that window, type ipconfig and hit enter. This will give you your PCs IP address along with some other information.
If your cable is bad, you will receive a "media disconnected" message. (try another ethernet cable)
If your connection is good but your PC is unable to get an address from your router, you will have an IP address of 169.254.x.x (x = a number from 1-254) If this is the case, try resetting your router by first powering it off/back on. If that doesn't work, you may want to try a reset to default settings. (usually there is a tiny button on the back of the router you will need to push in. Check Linksys site for specific info on your router model)
If your PC is getting an IP from the router, it will be in the 192.168.x.x range. If you have an IP in this range, your router connection is probably fine.
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor...
(More)
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor NAS 110 network storage and the NAS 110 cant pull an ip from the router when it is connected.
i hv a DIR-655 router & i've lost my manual. i want to secure my router and lock out others...
(More)
i hv a DIR-655 router & i've lost my manual. i want to secure my router and lock out others outside my residence. can you take me thru the steps?
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by...
(More)
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by Port Forwarding router??
No longer able to connect laptop to the internet with wireless modem. Have had to disconnect and...
(More)
No longer able to connect laptop to the internet with wireless modem. Have had to disconnect and work only from desktop. Have used this for a couple of years and suddenly stopped working. I can see the connection and everything looks fine but unable to connect.
