Question about Toshiba e-Studio65 Copier
FINISHER PROBLEMS The finisher on my toshiba e studio 65 has stopped feeding paper. The copier works fine other than it wont run through the finisher. It is getting power when plugged into the copier though. I took the side cover off and the LED lights are lit up, but there is no other sign of it registering with the copier.
Firstly you have to check what teh copier is set on i.e tray1 or tray2 , select one of the trays,and try to print this should work if , otherwise place the paper on bypass tray right hand side try this, somtimes the sensors are displaced which detect paper, try this and let me know.
Posted on Aug 18, 2007
I have a toshiba e-Studio 351c show E030 , i was remove the paper jammed but the machine not work and still show E030
clear very well the paper path especially if there is bridge who trasfer the paper to the finisher and check the sensor inside it or check if there is any load at the main motor
Nov 30, 2011 | Toshiba e-Studio 350 Copier
I have a toshiba e studio 3510c that is getting a c580 code. any ideas on how to resolve this issue or what may be causing this to happen?
[C580] Communication error between IPC board and finisher
(1) Check if the specified finisher is attached.
(2) Check if the harness connecting the IPC board and the finisher controller PC board is disconnected
or open circuited.
(3) Check if the conductor pattern on the IPC board is short circuited or open circuited.
(4) Check if the conductor pattern on the finisher controller PC board is short circuited or open circuited.
(5) Replace the IPC board.
(6) Replace the finisher controller PC board.
May 27, 2011 | Toshiba E-Studio 3511 Color Copier
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
Paper jam and message C570 - Call for service
The C570 is a communication error between the finisher and the main unit. Check to make sure the connector from the finisher to the copier is plugged in properly.
You could try re-seating connectors on the finisher board - it may help.
Make sure the power supply to the copier is not being shared with some other piece of equipment (like on a power strip) that could be causing interference/noise to the power supply for the copier.
If problem persists..could be bad IPC board(finisher) or CPU board (copier).
Hope this helps
Apr 17, 2009 | Toshiba E-STUDIO 850 Copier
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
Misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
Misfeed in finisher
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Oct 19, 2008 | Toshiba e-Studio 232 Black and White...
E-studio 810 problem
There are a couple of different switches that could be out of alignment, or not "making" when you reconnect the finisher. If you will look on the copier, at the latch that connects the finisher to the machine, you will see a pointy shaft about 2 inches long. This rod comes in contact with a switch inside the finisher. There is a metal actuator on this switch that could need adjusting. Not a difficult job, but it will require you to take a few covers off. Also, there is a black push button on the finisher that is actuated when you push the finisher to the machine. If you are looking at the back of the finisher (the side that connects to the machine) it will be on the lower right hand side. It it operated by a connecting rod inside the finisher. This rod could have come loose. Again, not hard, but requires cover removal. Also, when you locate this particular push button, try manualy pushing the switch to see if this makes you message go away.
As for the black spots, this could be any number of things, but I suspect that that it might need a cleaning blade and brush, and maybe just a good cleaning in and around the drum unit.
Hope this helps,
C
Sep 27, 2008 | Toshiba E-STUDIO 650 Copier
E-studio 28 copier
You may hve to adjust the finsher to close with out any force. There has to be a inter-lock switch that has to be closed to show that the finisher is closed.
Jul 15, 2008 | Toshiba e-Studio 35 Copier
Toshiba e-Studio65 Copier Logo
99 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
