Question about Philips 42PFL5332D 42 in. LCD Television
Phillips 42pfl5332d Wont turn on!! BRAND NEW!!
TV worked for a day and on day 2 my daughter yells "dad the t.v shut off. I turned it back on and it shut off a minute later. Now when I try to turn it back on a blue power light comes on for a second then a red light flashes 6 times over and over again. I unplugged it over night and same problem. Heelllpppp.
  • axp1277 Jun 08, 2008
    Having the same exact problem.
Same F'ing problem. First 6 digits are YA3B07
Posted on Jul 20, 2008
    Scholar:
  • 72 Answers
I see this problem with this model of TV alot. U have a bad power supply. Don't know if u want to fix or not ,but if your interested remove to back cover and in the center of the power supply you should see a fuse with a yellow stripe right next too it is there a capacitor thant is leaked ? ( just wanting to know out of interest what is the first 6 digits of your serial number, trying to gather information on this particilar problem On the right hand side of power supply where the power plugs into it. there should be a number LJ44-000119A ? If you could let me know it would be greatly appericated.
Posted on May 03, 2008
    Genius:
  • 1,153 Answers
This can be a major problem, I would box up and take back to store and demand a new one. They have to give you one, it's been only a few days. Say was damaged in shipping or damaged on floor.
Posted on Aug 16, 2007
SOURCE:
I have just bought a brand new remote for my Phillips 42 inch LCD tv from a reputable phillips website as the old one was not working (I recently bought it from my mate and his kid had eaten the on button...
Sounds like the IR sensor in the TV may be faulty, since you have now tried a couple remotes. Make sure nothing is on the IR sensor like tape, plastic, etc. IR sensor repairs are a fairly cheap and easy repair that can be done at your local tv repair shop. If you are still in warranty you can call Philips and tell them that you tried 2 remotes (1 brand new) on the TV and neither work. They should offer you a repair option. If you have any questions regarding your Philips warranty let me know.
Jul 18, 2011 | Philips 42PFL5332D 42 in. LCD Television
Tv will not turn on, red led flashes 7 times ???
Could be a power issue. Contact Phillips and/ or contact a licensed Phillips repair shop.Have your warranty details ready if it is till valid.
Jun 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Tv wont turn on. there is a ticking sound coming from the back. whats the problem?
bad power supply...try to check for any bulgy capacitors mostly electrolytic type...also check the transistors for switching...if needed repair I recommend to bring it to a service center...nice day..
Feb 12, 2011 | Philips 42PFL5332D 42 in. LCD Television
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
My phillips flat tv won't turn on?
I have come accross a lot of complaints regarding philips tv's, with premature failures the common ailment. I have filed a complaint at the following:
http://www.consumeraffairs.com/class_actions/
Click the "complaint button" and fill out the form. If enough complaints are filed, an attorney will review them.
Apr 15, 2008 | Insignia 42" LCD Flat-Panel HDTV
Philips 42PFL5332D 42 in. LCD Television Logo
507 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
