DONT SEEM TO RECORD ON TO A DISK USING DVD-R COMES UP READ ONLY THESE ARE NEW ONES
Make sure you are using DVD - (NEGATIVE) R disks there is a dff between DVD+R and DVD-R take a peek at your disk this unit appears not to work with DVD+R
I've had the same problem with some disks and not with others. The only solution I've found is that you can turn off the recorder, with the disk in the machine, wait about 30 seconds and turn it on. If this doesn't work, unplug the machine from the wall, wait 30 seconds and plug it back in. This usually works.
If neither of these work, the disk is bad.
