Question about Toshiba 65H80 65" Rear Projection Television
65h80 I have a 65h80 it has sound but no picture. We had a tech look at it he said it needs a high voltage transister(stk392-110) can I get one and install it myself
    Genius:
  • 1,153 Answers
Yes look for www.bluestar-online.com and check your set and make sure it's the stk392-110. If you can solder you can carefully change it. I would replace all, you may have 2 or 3 in there. Also make sure you don't bridge the pins. Meaning soldering 2 pins together, just be careful. Unplug set and be careful of unscrewing board.
Posted on Aug 15, 2007
SOURCE:
No picture, high voltage cable sparks at left tube/gun at turn on
It sounds like you have a shorted picture tube.
You should call a good TV Tech to confirm this and get an estimate.
Jul 29, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
TV made a very loud pop and shut off. When trying to turn it on again, just get a buzzing sound.
Sounds like you blew the horizontal transister in the CRT's high voltage circuit. It's common with tv's that are old or full of dust on the inside.
Nov 08, 2008 | Televison & Video
RCA 32V434T Changed recomended part: New Problem
Was the xformer RCA, new in the box ?.........
The silicon rubber seal is to moisture entry. Do not re-apply.
Make sure your connection is good.......
Did you hook-up signal to verify no sound ?
NSNP , HV ok = something wrong other than xformer....
Check all power supply voltages.....................T.
Check top of electrolytic caps for expanded,bulged or
what techs call "pooched".....................
Apr 17, 2008 | Televison & Video
Sound but no picture
loss of picture with sound ..loss of picture could one of many problems.. these units have serval specal fuses that a tech would need to check. loss of high voltage is a possibility. i would think this would be worth getting a tech to check out, the fact you still have sound may be a positive,
Jan 03, 2008 | Televison & Video
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
TV PICTURE DOES NOT COME ON, OR NO SOUND
check the bu transister in the horizantel stage and see if it has any voltage reaching there. if not. take the transister and check it out. I think it is needed to be replaced. good luck
Mar 22, 2007 | JVC AV-36890 36" TV
Red drained out of picture
The red transister on the CRT socket could be at fault. there is 3 transisters on the socket check for the voltages on all 3. If the red is high unplug the socket and see if it normal if not the transister or circuit feeding has a short. If low the same case seneral applies and a resistor feeding the transister is defective or the transister itself is at fault
Aug 28, 2006 | Panasonic CT-32SL15 32" TV
Toshiba 65H80 65" Rear Projection Television Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
