Sharp HTDP2500 System Logo
A
Anonymous Posted on May 22, 2013
What Wires Do I Need To Connect The Speakers - Sharp HTDP2500 System
What wires do I need to connect my denon avr-1803 to the speakers
All you need is some speaker wire long enough to get to each of the speakers your running. Use larger gauge if your running big speakers hard and/or over longer distances. Otherwise a medium gauge (16) will do fine.
You'll also need all the cables required to connect external components.
Where does the black and orange wires connect to?
Gateway computer is the only retailer of these speakers as of June 2003.
You need to provide more info about what connectors are available and how mant orange black wires you have.
4helpful
2answers
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
2answers
WHICH WIRES DO YOU CONNECT
use audio grade copper wires . .
2answers
I need to know what the coloured wires are(which is live,speakers etc) for the radio from the car.Somebody has cut the block off so i just have a load of wires where the radio goes.
black is ground, red is hot, yellow is memory,blue is activation wire for amps or antena ,speakers are green ,gray and white ,and purple negetive and positive wires to each of those colors .
1helpful
I have no idea how to connect these speakers all I have is the wires for the 5 speakers and a power cord for the sub any help please?
You have not mentioned -- connect it to what ???. Assuming that its an AV receiver. Start by connecting the front three speakers to the the amplifiers speaker sockets labeled Left front / Center / Right Front. These are connected using three short wires. Then connect the two surround speakers using the pair of long speaker cables. You will need a RCA to RCA cable to connect the subwoofer to the Receivers subwoofer preamp out.The subwoofer also requires an A/C wall socket to power it.
2helpful
When i connect the wires from my receiver to the top "red/white" connectors, the tweeter works fine, but the two midranges don't have any sound. When i connect the wires to the bottom connectors the...
are the two connectors on the speaker itself i belive you need two diiferent cables coming from the radio ect
what yu can do to make it work
connect the bottom connectos to the top connectors keeping the polatrity the same though
1helpful
2answers
Connect speakers to laptop
If the speaker you want to connect is from other devices(not a computer speaker )then you need an amplifier .Connect the speaker to the amp. then connect the laptop(output) to amplifier (input)the cable you need is "dual RCA male to 3.5mm male audio" .here is the link to view the cable that you need.
http://www.cablesnmor.com/rca-mini-stereo.html
Wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
