Question about Motorola Mobility RAZR V3
Motorola razr Keypad unresponsive with the exception of the power button. Knowing that a common problem is poor connection of flexi-connectors, took phone apart, cleaned and reconnected. Repeated this about a dozen or so times with the same result: Either keypad OR display working, never both at once.
Sounds like bloken flex / keypad module (mine did the same, all keys dead except power, fixed it with a 5 dollar new module and some hours of puzzling to get it installed.. (I just posted a guide on motox on how to do it.. http://www.motox.info/showthread.php?t=51009 (I hope urls are allowed)
Posted on Aug 19, 2007
SOURCE:
Hey, I have a motorola Razr v3 and the all the buttons except the on/off button stopped working. Any idea on what to do?
keypad has certain flex connector.might getting stuck or the keypad membrane is dirty.
otherwise it needs a replacement
Jun 07, 2011 | Motorola Mobility RAZR V3
Send (green button)has become unresponsive.
This problem is not very common with Motorola RAZR.
If other buttons are working except for the send button, then I think that this is a hardware-related problem. Unfortunately, we cannot easily take the keypad off the Motorola phones because it's a bit different from other phones.
I would suggest to bring the phone to the authorized repair shop and have them repair it for you. I'm sure that it's not caused by software or any other problems, but it's a hardware problem.
Thank you and good luck!
Jun 18, 2010 | Motorola Mobility RAZR V3
It won't dial
Check phone liquid ingress keypad connector to main board,swap another flip,if ok,replace keypad or display.
Aug 17, 2009 | Motorola Mobility RAZR V3
My v3 keypad- except for the on/off is unresponsive
Check,connectors keypad to main board,could be corrosion or check" on and off" button could be dirty,if not try to swap another flip,if not replace Gcap3 Ic near the battery contact.good luck to you
Van
Aug 16, 2009 | Motorola Mobility RAZR V3
Motorola V3 keypad not working
the flexcable need to be replaced in the phone
Apr 19, 2009 | Motorola Mobility RAZR V3
V3 unresponsive Keyboard
TRY TO CLEAN THE KEYPAD MEMBRANE OF YOUR UNIT..ASK A TECHNICIAN TO DO IT...THEY USE SPECIAL SOLUTION CLEANING THE KEYPAD & THE MEMBRANE...
Jan 27, 2009 | Motorola Mobility RAZR V3
Won't power up
Device is bad or needs reset, remove the battery while the device is on and count to 30 then re-apply battery and power on!
Sep 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Keypad does not work
I had a common problem which none of my keys worked except the "off" key. I baked my phone in the oven on the lowest setting for 20-30 minutes and it works now. It is a humidity issue.
Mar 16, 2008 | Motorola Mobility RAZR V3
Motorola razr keypad seems locked???
It seems your Keypad Flex is messed up. common issue on the v3 - we can fix this for you - $25+ shipping
http://horizonwirelessonline.com
Jan 21, 2008 | Motorola Mobility RAZR Cellular Phone
Frozen buttons except red end call button
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Sep 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
125 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
