Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint ultima 1200 washer/dryer
On the drying cycle my machine just fills with water and leaves clothes wetter than when they have been on a wash cycle? Everything else is working ok.
  • Anonymous Mar 23, 2014
    tumble drying with hoover washer dryer and the washer draw fills with water
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Posted on Oct 07, 2007
    Novelist:
    Champion:
  • 244 Answers
Sounds like a faulty timer the washer should not fill up with water when drying hotpoint w/dryers let the water out of your outlet pipe so there not supposed to fill up m8
Posted on Aug 15, 2007
6ya staff
SOURCE:
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Dryer not working. Clothes wetter than when they went in?
Could be that the RPM is not enough for the spin as the BELT is loose or slipping or if the motor speed is less due to a worn out CAPACITOR.
Try with a longer drying time or manually dry to confirm .
Also check if the inlet valve is working at any time during this cycle to we the clothes, if so there could be output from the control panel which could be a suspect.
Jul 05, 2012 | Fagor 24" Washer/Dryer Combo with LCD...
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint 1200 aquarius washer dryer
take top and back off. locate the dryer duct which comes from half way down and goes across the top of the machine via the fan. blockages in duct are common especially the plastic part of the duct
Oct 16, 2008 | Hotpoint Ultima WD72 Front Load...
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washer not working
i had this and the timer circuit was faulty i found a few dry solder joints. i re soldered it and cured the problem.
Jan 14, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
281 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
