Question about Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO 2200BG will not detect any network
I have a WInbook with an Intel PRO/Wireless 2200BG modem. It used to detect networks fine, but recently stopped detecting them. When I go into Device Manager, it is enabled, there is no yellow exlamation point next to it and properties tell me it is working correctly. I have tried to uninstall it and reboot. It then reinstalls it, but it still doesn't detect any network. I have a USB and also a PCI wireless modem which will detect and connect to networks with no problem. Any ideas on how to fix my internal one? I hate having to plug in these everytime I travel. Thanks.
  • 1 more comment
  • Clive Burke
    Clive Burke Sep 13, 2008
    Hi - cannot detect my network with my IntelPRO/Wireless 2200 BG card. It will detect the network next door, but not mine, even though the network is up and I have other computers on it, one with an identical card, have tried swapping the cards over, and the problem moved with the card. So the problem is definitely with the card. have tried new drivers.
  • DYERC21 Dec 05, 2008
    Recently changed modems and now Intel PRO 2200BG Still detects networks but can not connect to Internet Wirelessly. Can connect via cable through same router but not with Intel PRO Wireless 2200BG. Any Ideas?
  • jii2000 Dec 26, 2008
    my wireless used to to work great, but as of late it wont detect any networks. to be more specific. it will not show any networks when i click "view wireless networks" i will see it trying to connect to other networks, but never quite make a connection. when i boot up, it says wireless networks are within range but will not display them. when i try to manually add the network, it will show up only that once, and wont be there when i close that window. i have had this for nearly four years, and this just recently started
  • 3 Answers
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Posted on Sep 07, 2007
  • 56 Answers
Is there a physical switch or a software switch (fn+F2) or anything on that laptop that you may have inadvertently switched or bumped??
Posted on Aug 15, 2007
    New Friend:
Check your wireless channel. My router config was on 13 and the network adapter on 10. After I changed the router's to 10 it started working.
Revisa tu canal wifi. En mi router estaba en 13 y en el pc estaba en 10 (con un maximo de 11). Tras cambiar la configuracion del router a 10 empezo a funcionar.
Hope it helps.
Danimal
Posted on Dec 10, 2012
I'm having the same problem with the same wireless modem. I have a physical switch and have tried it repeatedly - but it does not seem to work. There is an indicator light that should light up when I press the 'wireless connect' button - but it doesn't. My device manager also says the modem is working properly, but it clearly isn't. My neighbour can see my wireless network but my laptop doesn't see it.
Posted on Aug 29, 2007
I have an HP/Compaq 8230 that is 3 1/2 years old. Recently, my wireless has stopped working. "No networks found in range". It is an Intel PRO/Wireless 2200BG.
Do a wireless scan and see how many wireless connections are avaiable in your neighbor. If I was a beating men, that your wireless router is sharing a neighbor's wireless channel number.
Dec 09, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Describe your Intel PRO/Wireless 2200BG 802.11g/b
SO you are not able to connect tyo the wireless network.
what is the operating system on your computer ?
Click Here for more info wireless connection
Oct 08, 2009 | Intel PRO/Wireless 2200BG...
I've updated the drivers but it won't show up as the new version in my updates, any ideas why? I'm having a hard time getting it working properly again.
you do properly update it re-installed the driver remove the device from the laptop then again fix it after then installed the driver i give this link to use this driver you get it
http://download.cnet.com/Network-Intel-R-PRO-Wireless-2200BG-Driver/3000-2112_4-109085.html
http://download.cnet.com/Network-Intel-R-PRO-Wireless-2200BG-Driver/3000-2112_4-109083.html
this two link you help you to solve the problem
Apr 29, 2009 | Intel 2200BG 802.11g/b (wm3b2200bgmwwb)...
Wireless network found
If it cannot find any networks, check to see if there is a wireless on/off switch on the computer - look carefully some are well hidden. The switch turns the antenna on and off but windows still detects the network adapter and thinks everything is ok.
Sep 07, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Long load up time on windows startup
The chat got diconnected, apologise for the same. Some times that chat tool acts up.
What we need to do to help you resolve the problem is to uninstall and reinstall the wireless driver.
1. Connect the ,laptop to the wireless router using a network cable. So that we have stable internet connection
2. Click on start and go to control panel, open Add or remove programs
3. Uninstall Intel Pro wirelss and click uinstall
4. Restart your computer
5. Download the updated driver for the wireless connection from the following website
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62875
Save the file on your desktop: 7kwc50ww.exe
6. Double click on the file and install. Reconfigure the wireless settings
and it should work fine
Thanks
proton
Aug 01, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
I have an Intel PRO/Wireless 2200BG.... Modem
That is hardware issue ( the modem is bad ) replace the modem and it will solve your issue .
Jul 24, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
System Crash
Hi
Intel 2200BG is known to cause this and similar errors when Wireless Application Protocol (WAP) encryption is used. The problem has been around since 2004 and new OS Drivers should fix this.
I recommend you download and install latest Windows Drivers (appropriate for your Windows Version) for Intel 2200BG Adaptor.
If this cannot be done, then setting your wireless to Wired Equivalent Privacy (WEP) encription (though less secure) will minimise these error conditions
NB: Google "w22n51.sys" for more info.
Regards
Mike
Mar 27, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO/Wireless 2200BG 802.11g/b Logo
1,622 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
