Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Jenn_air model #JD8910AWS won't drain
My Jenn-air dishwasher model #JD8910AWS won't drain. The motor recently burn and I replaced it and now it will star the wash cycle but when it tries to drain the motor will only start and stop over and over. I assume this is why the original motor burnt. Have you any idea what this problem is? Thanks George
  • ghelmer Aug 16, 2007
    When I replaced the motor the new one came with a new impeller and pump assembly.As far as I can see everything is clear.Im assuming the the motor cycling on and off burnt the original motor.Could it be in the electronic's in the door? or would there be a sense of some sort that would be defective that would do this?
    Thanks
    George
  • ghelmer Dec 13, 2007
    Thank's to wvolve my dishwasher is working again......
    thanks again
I was having the following symptoms: If I hit the drain button, it would stay at 2 minutes and just click on and off. If I hit the rinse button, it would rinse all 9 minutes OK. It would always stick in the middle of a full cycle and just start clicking.
I just fixed it. I shut off the circuit breaker, opened the door up (all torx screws from inside of door) to get the the upper controls. One lead (of two) of a capacitor (square blue component) had actually worked itself out of the control board. I cleaned it up and resoldered it in. All better now - for now.
Posted on Dec 06, 2007
  • 641 Answers
Since you already replaced the motor, it sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck!
Posted on Aug 15, 2007
  • Dov Dror Aug 16, 2007
    Try to close the water tap to the diswasher and check whether you still face the problem.
SOURCE:
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Jenn air dishwasher won't fully drain
Your garbage disposal is clogged . Or your hose from your garbage disposal is flowing in the down position
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Jenn-air dishwasher jdb1090aws wont drain
Most common issue on this model is the drain motor itself. More times then not it gets clogged with debris. Pull the unit out and remove the three screws that mount the pump to the bottom of the dw.
take the hoses off and clean the drain motor out. It will fix this issue I have seen it more times then you could imagine. Good luck with your repair friend
May 19, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Water not draining out
Look where the drain hose attaches to the garbage disposal. Make sure the knock out plug has been removed.
Feb 23, 2010 | Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Jul 19, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
Jenn-Air dishwasher: error code C2 and C1
This is not a JDB6510 Model. Check the inside label when you open the door.
Sep 09, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
May 31, 2008 | Jenn-Air 24 in. DW961 Built-in Dishwasher
Jenn-Air JDB890AWQ stopped middle cycle no motor activity or sound
no real reset, nut you can check for power leading to the unit, make sure the bnreaker hasnt tripped , and next if you remove the bottom acees panel you lfind a box to the right . the electrical conne\ction is made behind ther make sure the connection hasnt shaken itself loose.CAUTION LIVE WIRES BEHIND THAT COVER"
Mar 29, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
437 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
Mike
wroxter
Level 1 Expert
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
