Question about Toshiba Satellite Pro 6000 Notebook
Laptop wont power on.
Hi there. Bought a stellite pro sp6000 off ebay recently. all seemed to be running fine, clean XP install....great. the problem I hit was when, after disconnecting from the net at home (ethernet connection), now it will not turn on. the green power led comes on, but thats all, nothing on screen, no beeps, no power to dvd drive (wont even eject). If its any help, the last update to install was an optional update to .net framework 3. as far as i know, that was the last update i needed. Please help!!! Thanks.
  • Inzo Aug 15, 2007
    Neither....conflicting RAM was the problem. I had pc133 & pc100 in there. Took out the pc100, and....hey presto, it works again
  • addyfie Nov 02, 2007
    I have had my laptopfor a while it started to run very slow last week so i was adviced to format, which I did and now it wont start up. When the power lead is plugged in a green and an orange light come on but nothing powers up. please can anyone help????
    Problem Solver:
  • 11 Answers
Hi, regarding your problem, kindly removed your batter and use only the power adapter to AC. If is the same, your mainboard may be damage or it has a problem. You better bring it to one of the supplier or business patner of HP who provide for warranty claim
Posted on Aug 16, 2007
  • 196 Answers
Try booting with the battery removed. Other than that, this looks like a serious problem that will require a repair service.
Posted on Aug 15, 2007
I bought a laptop that needs windows xp pro installed to work
You maybe able to get a copy from your friendly computer shop or on EBay. Make sure you also get the Windows installation code with the Windows XP Pro CD.
Oct 01, 2012 | Dell Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          The problem seems to be that if I move my Toshiba sp6000 laptop the screen turns turquoise and scrambled. The only way to get it back is to disconnect power and cable ,then sometimes it wont even boot...
          What you have said is very likely a hardware issue instead of being related to the registry cleaning.
          Is the laptop covered by warranty?
          It seems like a problem on the video adapter, its most likely failing or a cable is loose.
          May 06, 2009 | Toshiba Satellite Pro 6000 and 6100 14.1...
          Inspriton 8600, XP SP1a not recognizing Integrated Net Controller
          try to run in safe mode.
          press F8 key when u power up then enter s safe mode.
          then remove sp3 f u enter success fully in safe mode.
          then type in run "chkdsk /r"
          then press enter "y"
          then restart the computer.
          Jan 12, 2009 | Dell Inspiron 8600 Notebook
          RAM uprgade doesn't work on Toshiba SP6000
          Hi
          You need these modules:
          PC133 512MB (PA3108U-1M51)
          PC133 256MB (PA3086U-1M25)
          PC133 128MB (PA3085U-1M12)
          Furthermore you can upgrade the memory to max 1024 MB
          hope this helps
          Leecom72
          Nov 13, 2008 | Toshiba Satellite Pro 6000 Notebook
          IBM Blue Screen
          I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
          It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
          I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
          System:
          IBM 6868 52A M-Pro Intellistation
          2 x Intel P3 866 CPU's 256 mb cache
          2 GB ECC RD Ram
          2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
          2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
          ATI 9520 AGP 128mb Graphics
          Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
          Dual Boots with Xandros Linux Desktop Destop 3.01C
          Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
          Inspiron laptop Battery won't charge
          Hi
          Update laptop bios go dell.com check for update of your laptop model....
          Thanks
          Jul 10, 2008 | Dell Inspiron 6000 Notebook
          Kodak i260 scanner wont work on vista
          This is a non Vista compatable product.
          It may run on Windows Vista 32bit Business though.
          May 05, 2008 | Kodak i260 Duplex Color Scanner
          Vista vs XP
          there are still some new model bundled with Linux, you can buy that one and instead of installing linux, install windows xp , you can have also the xp driver on it
          Apr 12, 2008 | Toshiba Satellite A105 Notebook
          1 GB MICRO SD TRANS FLASH MEMORY CARD AND ADAPTER
          hi,
          what is the brand of ur flash memory card. some doesn't get recognized in OS lower than XP.. you might need a driver for it... knowing the brand would help.
          regards.
          bzoy
          Jan 09, 2008 | SanDisk Memory Media
          Toshiba Satellite Pro 6000 Notebook Logo
          141 people viewed this question
          Top Toshiba Computers & Internet Experts
          pankaj rautela
          pankaj rautela
          Alun Cox
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
