Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Zanussi Freezer ZVC67 - replace the seal
I need to replace the seal on my freezer and have sourced the part. Question is, can I fit it myself, and how simple is is to do? Thanks
  • towser Aug 15, 2007
    any good suppliers of the seal you can recommend?
    Thanks
    Novelist:
    Champion:
  • 244 Answers
Yes u can fit it yourself the door seal shoould just push in which u might hear a small click when it is in properly not a major job m8
Posted on Aug 15, 2007
  • peter gittos
    peter gittos Aug 15, 2007
    there is homespares but your proberly better of getting from zanussi support itself email address is www.espares.co.uk/zanussi will be around £40-50 all in
My fridge/freezer is frosting cos the rubbers shot x local repairman says he will not fix as "it never works"x can I replace them myself? difficult? x leroy
most places have a " seal-a fridge " type business that comes to your place and makes and fits door seals to fridges and freezers
check in the trade pages of the phone directory or go google and type in--- fridge door seals and repairs -- to see if there is a business close to you
the only problem that you may have is , if the door and seal edge area is badly rusted
if you can get a seal from a service agent spares and you have some ability you may be able to fit the new seal your self
Nov 22, 2016 | Refrigerators
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Need help on freezer build up and freezer not getting cold
    try defrosting it manually. unplug it and let it sit with the doors open for about 4-5 hours and make sure the doors close and seal all the way.
    May 22, 2009 | Zanussi ZEBF250W Bottom Freezer...
    How to fit a Zanussi fridge door seal
    You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
    http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
    This should help!
    Brad
    May 21, 2009 | Refrigerators
    Haier freezer chest not cooling. Green light is
    Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
    jim
    Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
    Zanussi refrigerator/freezer model ZX99/5
    I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
    This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
    If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
    hope it helps.
    Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
    Replacement glass shelf required
    Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
    Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
    Frost in Chest freezer
    Not much you can do except ensure you have a tight seal and not to open it more than you have to.
    Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
    Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
    235 people viewed this question
    Top Zanussi Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Colin Stickland
    Colin Stickland
    Jason Harris
    Jason Harris
    Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
