I got this projector, but cannot get it going. The lamp is lighting and I have it connected through a 15 pin D-Sub ( supplied with the projector) to my labtop, but it will not pick it up. When I press the menu button nothing happens nor either with the input button. Help to get this going would be great
-   I hook up the projector to my personal computor exactly like I hook up my friends. No image to projector screen, so I hold FN and press F7, But still no My freind activates the link on mind but it does not stay-active, for me to get the data to the projector.-   Guest
Denis, by default laptops usually output only to their own lcd panel. There must be a key combination on your laptop wich rotates output in 3 steps: lcd panel only, lcd + TV (projector), TV only. The key combination uses a special Function key (FN) usually blue (found near left Ctrl key)with one of the numeric keys. So, first make sure your laptop output is correct and then try input key on your projector.
I am restoring an about-60 year- old 8mm Bell and Howell projector. It has a square plasic Filmo...
(More)
I am restoring an about-60 year- old 8mm Bell and Howell projector. It has a square plasic Filmo Projector Oil bottle-empty. Can you tell me where I might ind some of this oil-preferably but not neccessarily- in the original container?
I was watching my projector when all of a sudden we had a power cut. The projector still turns on...
(More)
I was watching my projector when all of a sudden we had a power cut. The projector still turns on but there is no response from the lamp. The lamp/cover light dispalys on the front. For some reason I do not think it is the lamp but rather a fuse. Does anybody have any solutions? cheers
While traveling with my Sony VPL CS4 to Romania, I plugged in the projector. The standby light came...
(More)
While traveling with my Sony VPL CS4 to Romania, I plugged in the projector. The standby light came on, but pushing the button to power up the lamp did nothing. I assumed the lamp had blown and purchased a new one. After installing the lamp as per the instructions, I still have the same problem. The projector will now power on. Any help would be appreciated.
