Question about Canon MV650i Mini DV Digital Camcorder
Canon MV650i Starting camera into recording mode, the start-up procedure halts and there is only blue screen with "canon" logo. In servise center they adviced me to either replace electronics of optics or even whole base plate. Is it really necessary ? Why they just do not find a broken conponent on the PCB ? Should be much less expensive... Thanks,
  • 1 more comment
  • Miroslav Aug 15, 2007
    The camera is not anymore under warranty.
    The blue color is same as at stopped play, but with logo CANON in addition.
    I bought it in Czech Republic.
    Bye,
  • Miroslav Sep 07, 2007
    Unfortunately it is not CCD problem - that one I already had and the sensor was replaced 1 year ago, for new one. Those time there was completely black window, switching to recording mode. Now it is blue, with Canon logo - I think someting stops the start-up sequence at time the camera is doing initiation tests.
    It is simple to dismantle the camera? Is there any opreating manual for this?
  • Ali shalash May 27, 2008
    no have software for my camera canonMV650i mini DV Digital
  • 3 Answers
I have canon MV650I DIGITAL VIDEO CAMCORDER please i need software
Posted on May 27, 2008
    Champion:
  • 206 Answers
Sounds like CCD sensor problem ( it sits behind the lens inside your camera ) and it should be replaced . With this problem you do not need to replace the lens unit itself or any other parts. See if you can have it done free of charge because these sensors when properly manufactured should work fine for +- 15 years...obviously a faulty one went into your camera.
Posted on Sep 07, 2007
    Problem Solver:
  • 12 Answers
First of all is it still under warrent? Did u get it at Sears? The blue screen looks like it would if u have it on play with it stoped?
Posted on Aug 15, 2007
SOURCE:
Need a manual for the Canon MV530i
To download the instruction manual for required product, please click the respective link below:
Canon MV530i Manual
Canon MV650i Manual (Product category selected)
Please rate the solution.... :)
Thank you
Dec 02, 2008 | Canon MV650i Mini DV Digital Camcorder
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Attention Fixya site I have a Canon Camcorder 750i Unit does not display in record mode either with screen closed for eye piece vision or screen vision fully open. This applies to either when...
Symptoms in your Canon camera shows problem with CCD Image Sensor. Canon website has advisory for this issue. Please click above link and see it. I couldn't find your model for Free of Cost repair list but you can ask Canon about your camera. Hope this info will help you.
Aug 17, 2008 | Cameras
I had the same problem a few days ago. I tried two different camera shops and they couldnt help and could only offer to send the camera back to Canon. I then decided to try changing the back-up battery (£3.50) and the flashing red light was the back up battery, that has now gone however I still have the black screen or a series of vertical coloured lines, which is obviously a different problem!
Jul 21, 2008 | Canon MV650i Mini DV Digital Camcorder
Cant play back recorded footage
you have to flick the switch on the side from camera to play
Jun 29, 2008 | Canon MV650i Mini DV Digital Camcorder
Canon software
hi
select your camera from here Official Canon Drivers and Software
and see what software is availabe.
riz.
Jun 02, 2008 | Canon MV650i Mini DV Digital Camcorder
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Blank Screen
Yes they'll fix this for free, see:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Note that Canon should fix this for you free Worldwide. Sorry, but I don't understand French. But here's a starting point for your search for repair help in France:
http://www.canon.fr/Support/index.asp
Dec 28, 2007 | Canon PowerShot A75 Digital Camera
Canon pal mv650i
السلام عليكم لطفا احتاج برامج تعريف كاميرا نوع كانون mv650i
Oct 27, 2007 | Canon MV650i Mini DV Digital Camcorder
Canon MV650i Mini DV Digital Camcorder Logo
151 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
