Question about Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo
Polaroid LCD TV TLA-4641C
The menu keeps flashing on and off. I cannot access anything with the remote or on the TV. When I press the input button on the TV it will stop the menu from flashing but I can only access the screen it freezes on, the picture screen.
  • Akai Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE:
Have a TLA-04011C 40 inch HD Tv. I cant get a picture now on either HDMI slots in the back. I also tried the Svideo,the video1, video2 in the rear. The only thing that will work now is the TV/CABLE/AIR...
Could be the input selector board not changing inputs. Presumably you have pressed the input button on the remote? What happens? Power down completely, remove mains plug wait 15 mins power up and try again. Also try a reset in the menu.
Jan 02, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Problem on polaroid 04011c not shoving menu display or volume or eny command
Does your set respond to the controls on the set itself?
If you, are you able to access the setup menu to perform a factory reset?
If so, press menu, navigate over to setup, then choose reset defaults, to see if that improves your situation.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
Polaroid TLA-04011C Service Manual Download
Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Tv won't change channels. push channel up or down button on tv or remote and nothing happens.
Are you set to view through the antenna input. If you are on any other input say watching though your cable box your channel button for the tv is not usable. You are using the tuner in your cable box.
Nov 01, 2009 | Polaroid TLA-01901C 19 in. LCD TV
TV scrolls through input sources on its own
To make sure the remote is still working, point the remote to the TV sensor, press couple of times and notice the Red LED is response or not. If the LED blinking, the remote works fine. The suspection now is the main board which is control all the inputs. You can try to get TV back to factory reset, it might help.
Aug 12, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid lcd tv sporadically cycles through inputs
If the side buttons are not jammed in, your button panel will need to be replaced.
Dec 20, 2008 | Televison & Video
Polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Jun 16, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Dec 21, 2007 | Samsung SyncMaster 17 in. LCD Television
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Dec 13, 2007 | One For All URC4220 Remote Control
Akai CFTD2052 20 in. EDTV-Ready LCD TV/VCR/DVD Combo Logo
441 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
