Question about Epson Stylus Photo R220 InkJet Printer
Espon Stylus Photo R220 Error
I've had my printer about 12 months and it's started printing only part of the page. It doesn't occur all the time although it's becoming more frequent. Have tried using maintance but doesn't fix problem, also tried rebooting makes no difference. Also have new cartridges in so that can't be it. Can you HELP???
    Genius:
  • 2,985 Answers
Look in www.fixyourownprinter.com
Posted on Sep 03, 2007
SOURCE:
No disc for epson stylus photo r220
Here is the support page for this printer. Links for drivers, manuals and more:
Epson R220 Support
Thanks for using Fixya.
May 23, 2011 | Epson Stylus Photo R220 InkJet Printer
I need to install an epson stylus photo R220 printer to my computer so i can print,but i dont have the software cd to install it to my computer. What do i do? How can i setup the printer to my computer so...
Hello, just google 'Epson Stylus Photo R220' and go to the Epson website where you will see a section marked 'Drivers and Support'.
You will be able to download your drivers from there.
Hope this helps!
Regards,
nicam49
Dec 22, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Stylus photo r220 not picking up 4by 6 inch photo paper
move the paper sideways (end on as apposed to flat) or select portrait printing instead of standard. good luck!
Mar 11, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer says "ink is out" when I try to print but it's not
this mean your printer waste pad maybe full and the printer needss to be reset download the ssc and it will reset it for you
Mar 03, 2009 | Epson Stylus Photo R220 InkJet Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to [email protected] thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Printer Spooler
Exactly what it says...(smile) Click on start click on run Type services.msc A box will open up Make sure all items below are set to automactic To make the changes double click on each item change to automactic if diabled. Then click apply when you are done. Restart the compputer and try testing your printer again. Printer Spooler LexBce Server Remote Procedure CallRPC) Hope this solves your problem
Sep 16, 2007 | Epson Stylus Photo R220 InkJet Printer
Only One Ink Cartridge out of Ink But can't print
The machine needs all six cartridges. No way around it. This you could try go online download the Epson utility from www.ssclg.com Installit. learn to use it- click on the icon to set up the printer then right click the task bar icon and look at all the options With all six cart in place use rest set all colours Then try.
Sep 03, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
136 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
