Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Stuck Whenever I turn it my MP3 player on, it gets stuck on the EAX screen. When I plug it into my computer, it's not recognized. It won't turn off either. I dont' recall dropping it so I wonder what I can do to remedy this situation.
Try tapping it on the right side right above the menu button. I did this and mine began to work again.
Posted on Sep 02, 2007
  • 31 Answers
Thge hard drive gone bad, so the player won't load anymore, replacing the hard drive is pretty easy and will solve the problem
Posted on Aug 20, 2007
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
When I plug in the ac cord, the screen goes to Creative screen,
First thing,make sure your battery is charged.When you power on your player,put it close to your ear.If you can hear the hard drive (a faint clicking noise) then your hard drive may be stuck.When you power on player,tap coner of player on mouse pad while player is booting up.If it doesn't work,try again,tapping a little harder.This is a common problem with these players.Good Luck
May 12, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My Zen Mozaic is stuck on the start-up screen.
Never mind, I got it. I just let the battery drain all of the way and then charged it. It worked fine afterward.
Feb 15, 2009 | Creative Labs Creative Technology Zen MP3...
what kind of reset hard or soft? let the battery die then recharge that should get it out of that loop its stuck in
Feb 15, 2009 | Creative Labs ZEN Vision:M Digital Media...
Rca Opal 4208 Blank screen
If stuck on initilizing then firmware went bad.
You need to go to RCA website download the latest firmware.
After you download the firmware.
plug in mp3 player to your usb device of pc.
After its plugged in install the firmware.
While its installing windows should find the palyer.
Leave it plugged in for about 1 hour to give the battery time to charge a little.
Jan 14, 2009 | RCA OPAL M4001 MP3 Player
Stuck on but not playing and no button response
When the EAX screen appears tap it hard on the right side, just above the menu button.  Seriously, it works.  I had to tap several times, finally really hard, but the machine came back.  Many others have posted this tip.
Sep 10, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Phillips go gear stuck on Repaired all contents cleared!!!
i held the volume+ button in while i plugged the usb cable. the computer recognized new hardware was found. i opened the phillips device manager and hit the repair tab. it automatically ran a repair through the mp3. then i installed new firmware through the phillips device manager. i lost all my contents but windows media 11 sync all my music back. THANKS ANYWAY!!!!
Jun 27, 2008 | Philips GoGear SA178 MP3 Player
Stuck in "sandisk initializing screen"
To those that are having problems with the MP3 player not being recognized. With Windows XP there is a little Icon on your Systems Tray that is called the "Safely Remove Harware Icon". Not using this Icon when unpluging MP3''s or zip drives can cause your PC to no longer recognize it. Toshiba Satellite laptops are known for this, others probably have the same problem. The solution here is to install the latest update of the ACPI Flash Bios for the Toshiba Satellite computer. Maybe this is also the problem with other PCs. To prevent these problems allways click on the Safely Remove Hardware icon before removing the MP3 player or any USB flash drive
1 With your m240 set to MSC and connected, go to "My Computer" and "right click" on the "Sansa m240" icon and select "Properties"
2 In that window, select the "Hardware" tab
4. In that "All Disk Drives" window, highlight the "Sansa m240" drive and select "Properties" (at the bottom)
5. In that window, select "Policies"
6. And there, set it to " Optimize for Quick Removal" and click OK and OK again
Dec 02, 2007 | SanDisk Sansa m240 MP3 Player
Stuck m230
to put your mp3 in MTP go to settings, and then to usb mode, then click in MTP, i don't know how to solve the rest of your problem, sorry, hope you find a cure
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
76 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
