SOURCE: Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
SOURCE: Dometic fridge 'check' light keeps coming on...won't cool
Yes , the check light is there to tell you that your out of gas yes this is true but the device which switches to power is not changing over which will not let the heaters work and will not start the process of cooling, I suggest to inspect the switch and ensure that this is the case first before consulting a mechanic.
SOURCE: fridge does not cool on either gas or electric
either the thermometer is bad, the thermostat is bad, or your coils need dusting. Is your compressor running?
Also clean the condenser assembly. Also check the evaporator tray to see if it is wet. It should be.
You also can remove the rear cover inside the freezer.
Now, after the compressor has been running for about 25
minutes...You may have to leave the doors open to accomplish this, wet
your finger and touch the silver evaporator coils from top to bottom
and front to back. Does your finger tip lightly stick to these
coils all over? It should be.
Next thing is to check the air diffuser assembly.....This one should
have you nearing the end of this diagnosis. Good Job so far.
Basically you have a electronic damper control which they are
calling an air diffuser. It is located between the walls of the
freezer and the refrigerator at the top rear. It is a vent that
has a little motor controlled by the main control board according to
the readings the thermistor relays to the electronic control.
What happens is the little plastic door hinge breaks and the
motor turns but the door does not open or close as programmed anymore.
You may have to gain access from both the freezer and
refrigerator side to remove this to inspect it for a break. If I
remember correctly, there are little tabs on the freezer side that must
be depressed to remove it into the refrigerator side. If this is
broken, open the door manually about 1/2 of the way and reinstall.
SOURCE: Hi (Help Please) My Dometic 3 way fridge is not
heater element,
power transformer
thermostat
change over switch if fitted
