Question about BenQ FP737S-D 17" LCD Monitor
Screen displays fine for a second, then goes blank
I have this screen for about a year now. About two weeks ago this strange problem had started to occur. Whenever i turn my computer on, the screen displays fine for about a second, then turns blank while the led stays green. when turning the screen off and then on again, the Benq logo is displayed, and then the same thing happens - the display works fine for a second, then turns blank. This also happens when unplugging and plugging the screen again to either the computer or the power socket. It also occurs on several computers working with different resolutions and refresh rates. Both the power cable and the video cable seem fine for a non-expert like me. Thank you very much in advance, Dor
  • tracie531 Nov 22, 2007
    just purchased used from freind worked fine first day then it displays name breifly starts and goes dark power lite stays green if shut down breifly comes on then goes black much like problem guy haveing that brought me here
  • swingjoshi Dec 25, 2007
    Dorsh mine has started to do the same
    what action did you take. did you send it back to BENQ?
  • 63 Answers
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Posted on Aug 15, 2007
  • ernaserlikas
    ernaserlikas May 28, 2013
    Thanks. you help my.
SOURCE:
Start up screen has strange large icons and lettering
Are you in "SAFE MODE"? if not it only a display setting, it can be changed.
Oct 30, 2012 | Lenovo Computers & Internet
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Blank screen on Nokia 6085
Frist U Change LCD Second Change Display Strip Third Change LCD IC  In Last Flash Phone.
Apr 09, 2009 | Nokia 6085 Cellular Phone
Nokia 6126 screen not showing
the problem is in display...better change ur display and use it...
Sep 19, 2008 | Nokia 6126 Cellular Phone
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
573 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
