The bobbin winds in the bobbin holder in this sewing machine but it winds UNDER the bobbin?
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
SOURCE: bobbin winder stopped working
Either the winder rubber has worn down, or there may be some residue on the winder rubber, ot the winder may have seized through lack of oil which is quite common in that case it will need to be replaced
Testimonial: "This is helpful can I fix it or do I need to take to a repair person?"
