Question about Motorola Mobility RAZR V3c Cellular Phone
Dust inside of the main screen of my Moto V3
Hi, I have got alot of dirt/dust inside the main screen of my V3. The phone works fine no problems at all, but I cannot work out how to get inside and clean it. I know that there is nothing wrong with the screen because when the phone is switched off you can still see the dust inside. Can you help?
  • 34 Answers
If the phone is not under warranty the v3 you can easy lift the pastic covering from the front of the cell mark motorolla genly clean make sure the cell is off clean wiht some liqiud base cleaner make sure the front pasic is dry then gently put i back in palce
Posted on Oct 01, 2007
  • 29 Answers
Please check local service center if they can assist you on this issue.
Posted on Sep 30, 2007
SOURCE:
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Two keys periodically will not work - 1 and z - then if we keep hey depressed long enough, they work. Tried new batteries. What is lide expectatncy of thsi keyboard?
Should last a long time as long as the keyboard is being treated in a rough manner. I've had my keyboard for 3 years now and it still works fine.
Alot of times, dust or dirt gets in the keys and that can cause problems. You may want to use a can of air and blow underneath the keys to get extra dust or dirt away from it. That can cause keys act funky. Also any kind of liquid can cause problems as well.
Nov 26, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Water marks and dust on the INSIDE of Nokia 6085 LCD screen
Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
Mar 31, 2009 | Nokia 6085 Cellular Phone
I have a razr v3 when i turn it on it goes to hello moto sreen freezes, flashes on and off then when i try to turn it off with the off bottom it wont shut off i have to remove the battery.
try strip ur fone and clean it with a old toothbrush to get rid of dust and dirt leave it separted of 15 min and put it back 2 gether again
Jan 25, 2009 | Motorola Mobility RAZR V3
Moto Razr does not work with speakers off
you need the ear piece cable needs to be replaced.
Jul 18, 2008 | Motorola Mobility RAZR V3
Sand under screen of RAZR V3
Shoels,
You could replace the screen and glass lens/cover but I having done this procedure a few times, don't think it's worth it as the Razr is a fragile phone and the case's just snap fit together.
There are cell phone repair shops (depending where you are located) that will replace both the screen and glass cover for a fee.
I personally would just look for a shady spot to view my display in daylight, as the V3 isn't worth the trouble/expense to repair (in my humble opinion of course).
Good luck
Mar 18, 2008 | Motorola Mobility RAZR V3
Dust under main menu lens?
yes you can take it to a mobile repair tech and have them do that for you.
Dec 31, 2007 | Motorola Mobility RAZR V3
Dust behind the Screen
you can open the screen cover of your v3. if you have screws drivers thats fits the screws you can open it.
to open it, at the screen of your v3, theirs a 4 little rubbers. remove the rubber (be sure to secure it cause when it drops you have a hardtime finding it) and beneath it are the screws. after talking it off, you can now open the screen. just locate the clips to separate the screen.
no need to open the other side only the screen part...
Oct 27, 2007 | Motorola Mobility RAZR V3
Dirt under screen
if you look on the side of your phone you will see a whole on each side toward the front of your LCD. This is where the dirt is getting in. The best way's to cover them are a snap over protective case(there is a billion online for cheap) or a shuttle case. Otherwise email me at madnessrepairs@hotmail.com and I can give you a guide to cleaning out the entire phone. This should be left to a professional but the last case I ran into got charged almost seventy bucks for something my company does for $5. It can be done by beginners but BE CAREFULL,
May 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
