Question about Roper RAS8445KQ Top Load Washer
Broken belt the belt that makes my machine agitate broke. i got a new one,but i cant make it stay on.
    Novelist:
    Champion:
  • 244 Answers
Have u tightened your motor up if not u will have to do this to stop from coming off but the belts should have a set of numbers on it make sure these numbers tally
Posted on Aug 15, 2007
SOURCE:
Whirlpool washer. the agitator just stopped in mid wash. there was heavy towels. . could the heavy towels have caused the agitator to stop.? does the agitator come off.?
the agitator cam be removed but that will not be the problem
if it has a belt drive , probably the belt broke or the agitator solenoid /engagement lever has broken
you will need the model and serial number when you call the technician for a proper diagnosis
May 14, 2017 | Whirlpool Washing Machines
Need to make spin the agitator on a Hotpoint Heavy Duty Washer
Drive belt broken call GE Parts for new belt , They stock for all makes ,,
Aug 17, 2012 | Hotpoint Washing Machines
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Agitator does not rotate during washing , but rotates during spin dry
Is the agitator a back and forth or does it only agitate in one direction. While it is spinning if the agitation mechanism is broken the agitator will spin with the speed of the bowl and just freewheel. you need to look to see if it is a belt driven agitator, if it is buy a belt for your model number of your washer and find someone handy to fit it if you cant yourself. If it is mechanical agitator chances of fixing it yourself are slim. Weigh up the cost of parts and labor as well as call out fee for the repair man and check if its easier and cheaper to just get a new washer.
Apr 11, 2011 | Washing Machines
Agitator not moving
Sounds like your belt has either broke or just come off. Tilt machine back, look under for the belt. If belt looks Ok you still might want to replace it with a new one. Normaly when they fall off they have streched and will not saty on.
Please rate solution
Aug 28, 2009 | Maytag Washing Machines
Replaced belt but machine will not agitate or spin , but does let water in it
if it is a topload u have a bad transmission thats what broke the belt was trying to spin and couldnt
Apr 16, 2009 | Washing Machines
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Broken vacuum
check the belt it may have broke or stretched out
Dec 31, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
