When I put them into the dock, they dont charge. When placed in the dock, i push the button to on, and the charging light comes on, but it doesnt charge.
I am having exact same problem. It says to turn off the headphone power to charge the headphones, but no light shows that it is charging. When I turn on the headphones and place it on the dock it says it is charging. Please help!I am having exact same problem. It says to turn off the headphone power to charge the headphones, but no light shows that it is charging. When I turn on the headphones and place it on the dock it says it is charging. Please help!
i have the same issue--did you try replacing the batteries as suggested? did it work?i have the same issue--did you try replacing the batteries as suggested? did it work?
You can't post conmments that contain an email address.
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
ck that batteries are installed correctly and contacts are clean. Put the old batteries in, if it is not trying to charge them, sounds like the charger is bad.
Place the ipod in the dock and move it around a little. Mine was having the same problem, turns out my friend had bent the connector a little when she slams in her ipod and then yanks it out without removing her brick case.
Gently push the ipod forward or backwards till the charging symbol comes up on the ipod battery. I then filled in some putty around the ipod so it stays like that while it's charging.
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
I had a similar problem. If you look in the battery compatment you will see a small switch in the keyway that gets pressed down by the key (the plastic rectagualr bump out) on the side of the battery, if the battery is loose the switch does not get pushed down and the dock does not recognize the battery as a Kodak Batery that it should charge. I solved the prblem by taping a singe piece of paper on the opposite side of the battery so that when it slides into the slot it pushes the switch down, I've nver had a problem since.
