Question about Samsung Digimax S600 Digital Camera
Samsung s630 lcd white screen
When i turn on my camera, i see a bright white screen, the lens still opens, i can still take pictures and view on computer, but NOTHING is on my screen. i tried playing with buttons over and over, i hear beeps, like its going through all the menus, but i still cant see anyything, from what i can tell everything else seems to be working. help!
SOURCE:
SOURCE: blank lcd screen when camera is on
Same problem with an HP R817, not fixed by tapping / banging it etc.
Figuring I had nothing to lose I removed the back of the camera to get to the LCD, which is a simple job on the R817 - seven obvious screws.
Once open, prod / squeeze the ribbon connector and LCD frame where it enters the LCD, that'll be your most likely problem area. I padded mine with a small strip of plastic and now have a working camera again.
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: samsung S630 junk
I am Judy Malone in Tenn and I had my camera all in box and ready to mail back to place listed on camera box. I had worked on camera for last few days and to no avail. I got the notice via email today and the usual steps that I've read before.
To take batteries out, insert again. And to hold the ON button to keep camera powered. Then press Center button OK and press RIGHT 3 times to Setup2...
Well, I could not get my camera to co-operate past the Press Right 3 times to setup 2. Only the usual screen with a few of the icons showing my battery had power. It would not do anything past this.
Well, I got mad...(smile) and figured something had to be wrong as it kept showing a 32 for picts and I knew I had taken 414 at least on my Lexar 512 MB (SD).
I thought something must not be aleigned properly..some pins inside or somthing, so I GENTLE tapped the camera against my kitchen table... First one side, then the other..and GUESS WHAT. My camera came to life and has been working fine since. I HOPE this is a permanent fix...as I love the camera and have said so.
So, for what it's worth...try this if everything else seems to fail...but please do it gently. And start from the beginning.
Take batteries out, then reinsert...and GOOD LUCK.
I will post again...and let you know if this continues to work.
I am amazed.
judy in Tenn
Posted on Feb 19, 2008
hittin1
SOURCE: samsung s630 camera
okay.... Try this if lens is stuck out... look at the side profile of the lens... you should notice the it is not even.. the lens is probably stuck at a slight angle.. GENTLY force the lens to where it looks even... should fix the problem.... worked for me.
Posted on Feb 25, 2008
Same thing happened to me. All I saw was a white screen. So I took apart the back to have a look. I used http://www.lifepixel.com/ir-tutorials/fujifilm-s3-pro-digital-infrared-conversion-instructions.htm as a ref. I took the LCD screen out and put it back. The cable was not connected properly. Now It Works Great.
Hope this helps
Posted on Jun 27, 2009
SOURCE: The view screan on my Samsung S630 camera is all blurry
Hi Guys
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
Posted on Dec 05, 2009
When i turn on my samsung pl50, a totally white and bright screen appears and its impossible to view anything on that screen. All other functions are working. Its capturing pictures as well. But the...
Sound like a problem with your LCD screen, related with the CCD Image Sensor; since that you can view mode and setting displays, isnt the LCD screenviewer.
The CCD Image Sensor isnt a job that you can do it, I suggest visit your techinician service or apply if has underwarranty.
Good luck.
Oct 16, 2011 | Samsung SL202 / PL50 Digital Camera
My Samsung s630 digital camera has a totally white screen when turned on. I changed batteries, repeatedly turned on and off, switched modes, but screen still only white. The camera is taking pictures OK,...
Possible fault with the display unit. The display unit is not processing the video image and could be defective in this circuit.
Since the camera is working fine I would advice that you use the camera fully than to open to tamper. But if you are able to open with the prescribed tools then open to see if there is any loose links or visible faults like connection or dry solderring in the main board. However if the fault is a failure then we need to go back to get the part from Samsung.
Decide on with this advice.
Aug 25, 2010 | Samsung Digimax S630 Digital Camera
Hi Guys
Elizabeth Flood
Elizabeth Flood
Dec 04, 2009 | Samsung Digimax S630 Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
Samsung s860 camera got dropped turns on but screen is only white
dropping the camera might have caused damage to your LCD screen, best advise I could give is to send it in for repair
check if you can still view old pictures or if the on screen displays are visible, it will narrow down if the problem is with the lens or the screen
hope this helps
Mar 30, 2009 | Samsung S860 Digital Camera
Is your LCD turned off (for power savings) under preferences? That is the only thing I can think of besides a hardware malfunction.
Jan 27, 2008 | Samsung Digimax S630 Digital Camera
Blank lcd screen when camera is on
No solution for your first problem but it's normal that you cannot view your photo on the LCD screen before actually taking it. Due to the way a reflex camera is built, you can't have a live view on your LCD. The Fuji S3 Pro has this type of preview as also most recent camera (Nikon D300, Canon 40D...).
Dec 08, 2007 | Fuji FinePix S3 Pro Digital Camera
No picture preview bedore taking pic.LCD screen?
i cannot download pics from my camera to my desktop??
Oct 08, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S600 Digital Camera Logo
332 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
