posted by luzavala on Aug 15, 2007
I had the scanner off for a month with the adapter inserted, and today when I turned on to make some film scanning, the 35 mmm adapter is stuck into the scanner. I cannot take it out from the scanner. when I turned on and off the scanner, hasfunny noises caming from it.
Any ideas?
Thank you
Solution #1
posted on Feb 04, 2008
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Nikon Super Coolscan 4000 ED Film
Email this problem
Email this problem
Can you Help with these Scanners problems?
Nikon Super Coolscan 4000 ED Film Scanner (35...
helppp:(
helppp:(
i had to refragment my computer... Answer This...
Nikon 4000 batch scan
My scanner no longer offers me... Answer This...
nikon scanner 4000 won't load...
Roll adapter is connected ,film... Answer This...
Nikon Coolscan 4000 ED SA-21
Recently a problem has arisen... Answer This...
Repair Service
Find Scanner Repairman Near You:
