I changed my stereo in my 1994 ford probe and iam not getting any sound
Did you use a converter plug set for your factory wiring or did you do the siring your self. If you used a factory plug converter then your radio is probably bad, if you did the wiring yourself then check your splices and get a diagram for the wirring before you send the radio back. If you want a easy way to wire the radio in correctly the first time go to cruthfield and buy the converter cable for your radio and vehicle. Its $10 and saves you a lot of time an energy.
tepfy
Need to replace how do you ?
