Dehumidifier freezes up
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is freezing up. I see that the compressor does not shut off, causing ice to build up on the coils, rather than water draining off. What can cause this is your dehumidifier has been turned on recently. This is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another cause is if the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F and 96 degrees F. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Dehumidifier worked fine last year and now runs fine but does not pull in any water in the tank. HELP!
We have the same problem. We have a wine cellar with a dehumidifier on permanently, I had a tube going from the back into a drain which worked fine for a while but then stopped collecting water. I pulled out the tube but the reservoir is not collecting water either.
We have had 3 dehumidifiers over 7 years and the same thing has happened - still makes noise but no longer collects water. Are we doing something wrong?
