Question about Panasonic PT-47WX53 47" Rear Projection HDTV
PT-47WX53 blue convergence
The blue convergence is out of whack.Blue line curves up from bottom of picture.TV was serviced first year.CRT was changed.IC were changed.TV is 3 years old now.I can get into service but cannot fix this. HELP-THANK YOU.
    President:
  • 3,130 Answers
You will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Posted on Aug 15, 2007
PT51HX40B seeing shadow
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 12, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Red shift to left with curve at bottom
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Nov 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
The blue coloring is way off center
Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 20, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Rear Projection
You are on the right track. The problem is actually with the green convergence IC that controls the alignment. The convergence ic's take the information from the 3 pictures and align them into one picture on the back of your screen. Although this is an economical repair it is complicated and should be left to a quailfied service technician. If you are not sure of a local technician, panasonic's website has a servicer locator that can guide you to one. Hope this helps
Mar 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
124 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
