Question about Pentax Optio E30 Digital Camera
When switch the power just on for a sec and gone dead
When I switch on the pentax e30 On button the lense zoom out, the power indicator comes on for less than a second and then it just went dead. The battery, SD card etc are all fine - i am lost, please help.. Sam
  • 3 more comments
  • why31 Jan 07, 2008
    my zoom and lens are already out, but when i open the camera.. it works for about 2 seconds and then just turns off.
  • chocolo Apr 02, 2008
    my camera seems dead, the len remains out until i get to turn it on. It happens frequently, i already tried new an charged batteries. Should i throw it?
  • crytz58 Feb 08, 2009
    CAMERA WON'T STAY ON
    CHANGE BATTERIES KEEPS AYIND BATTERY DEPLETED
  • follie1993 Mar 12, 2009
    When i want to turn on my camera the indicator flashes 1 second and then it's gone. The battery is loaded.
    can u help?
  • Anonymous Mar 16, 2009
    Same problem with pentax e30 - suddenly shows a few second battery life -- tried contact cleaning and realigning the hatch door - all nada - my guess elec. failure of circuit.
Try new batteries
Posted on Oct 25, 2007
    Problem Solver:
  • 5 Answers
Hi
I find with most digital camera to use re-chargeable batteries as most common batteries will only last a few seconds - minutes at the most. Once I changed mine to re-chargeable batteries I have had no problems:)
Good Luck.
Posted on Feb 15, 2009
SOURCE:
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
Menu button is not working
My Optio E30 was not zooming because the small ribbon cable from the button strip was dirty/oxidized. All of the back panel buttons are on the same button strip. I needed to open the camera and remove the ribbon from the connector and gently clean the ribbon cable contacts with 600 grit sand paper. It now zooms perfectly.
Feb 02, 2010 | Pentax Optio E30 Digital Camera
I have an old Pantax 35mm SLR camera (zx5). Would the lenses still fit the new bodies or do I need to purchase an entire new kit?
Nope! Your old Pentax (and Taukimar!) lenses will still work. Any type of "K-Mount" lens will work on a Pentax digital.
Jul 01, 2009 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Lense problem
Dear The pro,
The vivitar v2000 definately takes pentax lenses but only k mount lenses.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 09, 2008 | Vivitar 600-1000mm (1200-2000mm) Super...
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
The Power Zoom appears to be locked at 80mm.
(I just cut-n-pasted the comment into the solution so this shows up as a solved problem in searches.)
"I've found the solution!
Just goes to show that sometimes it's worth simply calling the importer's service department, who told me in 30 seconds!!
Hold the zoom twist-ring and push, or click it up or down, depending on which way you are holding the lens.
So simple; I even accused him of not knowing what he was talking about.. and of course apologised profusely when it suddenly happened."
Dec 15, 2007 | Pentax Zoom Wide Angle SMCP-FA 28-105mm...
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Pentax Optio E30 Digital Camera Logo
197 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
