Question about Directed 2400d Car Audio Amplifier
Directed 2400 amplifier turned off and has not come back on?
Not sure why. The fuses are good. My radio lights up but the amp does not?
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description, three possible reasons: 1. There is no power going into the amp. The fuses may be good but there is no +12VDC in the big red wire. You have to use a voltmeter to check if there is 12V at the end of the line/wire before it goes inside the amp. In some cases, the fuse might be good but there is corrosion on the fuse terminals and the metal contacts of where it is placed; 2. There is no switching signal to activate/power on the amp. In some setup this is a blue, yellow or orange wire. This can be activated by either the ignition switch of your car, the headunit/stereo, or even a manual on/off switch. This has to receive a 12V also to activate the amp; 3. Internal fault of the amp. The big red wire has 12V, the fuses are good, there is signal 12v to activate amp, but still no power; there is something wrong inside the amplifier. It has to be opened up and diagnosed. This may involve component level repair, circuit analysis, electronics and soldering so you might be better off seeking the services of a qualified professional. Hope this gives you some ideas and work out for you. Good luck and pls post back how things turn up. Kind regards.
Posted on Aug 15, 2007
Radio amp fuse blows
problem could be radio.10 amp fuse for ignition switch power up radio display the 30 amp fuse for radio amp system in which that circuit hot at all times.
Nov 18, 2013 | 1998 Lincoln Continental
Radio won't turn on. Fuse blocks don't identify a radio fuse?
w/out amplifier; dome, and Cig. hint if you cigarette lighter is working and your dome light is working ,the problem is not fuse is the radio.
With amplifier. Amp, Cig, and Dome; again if cigarette lighter and dome light and amp fuse is good then amplifier is bad, or Radio is bad the only hint in this one is that the amplifier control sound if radio has ilumination then the amplifier could be the cause.
All this fuses are located by the lower left side of the steering column.
Jan 03, 2011 | 2005 Toyota Corolla
Have Power going to the amp. Amp does not turn on. Do i need a remote? Bought vehicle with amp in it. LXA 600 Power light does not turn on.
you need to make sure you have 5 things.
1. power connection to the battery/amp
2. make sure you have a remote line radio/amp
3. make sure you have rca's radio/amp
4. make sure you have a ground amp/car frame ( scratch paint away for good contact)
5. make sure the speakers are connected to the radio.
if all is ok then check the inline fuse from the hot wire from the battery is not blown and the fuse on the amp is not blown.if so replace them. with the proper amp fuse.
Mar 24, 2010 | Jensen LXA400 Car Audio Amplifier
Amp is connected to the + wire, shared with the car radio itself. When i turn on the car radio the woofer only ''booms'' around every half a second and gets louder, even when no music is being played. Amp...
the problem lies in your wiring . you need a amplifier wiring kit u can get best buy that can handle 650 watts and go direct to battery under the hood. just the battery positive running to the + on the amp.make sure the remote wire or the r+ on the amp is not hooked up to power.what radio do u have?
Mar 06, 2010 | Car Audio & Video
My amp is not working! i have a live from battery and a good earth,but still nothing,does it need to be earthed to back of head unit?
Do you have the remote turn-on lead hooked up?
There should be 3 wires on the power side of the amplifier.
Ground - to the car chassis
Power - to the car battery
Remote - to the remote turn on lead from the head unit. (this emits a 12V signal to a relay inside the amplifier for it to turn on when the radio does)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2009 | Car Audio & Video
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Safe light boston gt 20 amp
First,check the output functions of your radio.
Then test the power lead for 12+ volts and ground at the amp, also be sure the "turn-on/remote power" lead from the radio is supplying 12+ volts when the radio is turned on.
Good luck...
Feb 22, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Area 51
Well you could have a couple of problems... First, if you have a separate, non-fader output on your radio, make sure the volume on that is turned up. Also check the gain on the amplifier to make sure that is at a reasonable level, usually 3/4 of the way up. Check to make sure you have good connections and wires going from the amp to the speakers. Also make sure that the RCA cables you are using are good, I have ran RCA cables, to find out later that they got pinched in the reassembly of my car . A way to test this is get a set of RCA cables and run them directly from the back of the Radio to the amp without hiding them. I hope I can help.
-Andrew Hawkins
Apr 02, 2008 | Power Acoustik Area 820x2 Car Audio...
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Car Audio & Video Logo
85 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
